Author Topic: Wanted: Free C Compiler for Windows 7 64 or Windows XP  (Read 14202 times)
Offline LonghairTopic starter
« on: January 25, 2011, 07:42:43 pm »
I know nothing about computer programming so I bought a book "Beginning C" so I could learn. Unfortunately, they do not include or even say where to get a C Compiler at  :-\
Could someone provide me a link because I do not know what the differences are between C, C#, C++, etc. compilers or if they all work the same.
I can emulate Windows XP on this version of Windows 7, so that is not a problem.
Thanks in advance.
Offline DaveW
    • WattCircuit
Re: Wanted: Free C Compiler for Windows 7 64 or Windows XP
« Reply #1 on: January 25, 2011, 08:41:17 pm »
I rather like this one
http://www.bloodshed.net/download.html
It says it's a C++ compiler, but when you select a new project, you can choose C as the language. As a general rule, C will compile on most of those compilers. C++ as a language has everything that C has, but adds a lot more functionality on top.
C# is very useful if you're planning on making graphical applications on Windows (limited functionality on Linux) as all the code to create windows, buttons, dialogues etc. is written for you. Well, there's a lot more to both C++ and C# but as a quick guide...
If you want to lean pure C with no extensions (useful if you also want to run your code on MCUs), then this is a useful book as well
http://publications.gbdirect.co.uk/c_book/
HTH
Offline GeoffS
« Reply #2 on: January 25, 2011, 08:58:50 pm »
There's a version of the GNU c compiler called MinGW (Minimal GNU for WIndows).
It's free and well supported.
Offline scrat
« Reply #3 on: January 26, 2011, 12:29:31 am »
IIRC the free integrated development environment (IDE, in other words a text editor, link to compiler, other useful tools) dev-c++ uses the same compiler. I think it's a very good and easy to use IDE, and you usually don't have anything to setup for starting.
As C++ is an extension of C (contains all C), all C++ (standard) compilers must compile C code.
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Offline LEECH666
« Reply #4 on: January 26, 2011, 02:34:02 am »
Code:Blocks is a more modern Version of DevC++ (from Bloodshed).
I used both, and both are ok (I've only written rather simple command line applications so far).
Offline pb
    • blog
« Reply #5 on: January 26, 2011, 04:10:04 am »
Visual C++ Express is available as well if you are looking for an IDE.  You can still use the command-line compiler that is included if that floats your boat as well.
http://www.microsoft.com/express/Downloads/#2010-Visual-CPP
Offline RayJones
    • Personal Website
« Reply #6 on: January 26, 2011, 05:44:58 am »
Another vote for Visual C++ Express.
« Reply #7 on: January 26, 2011, 02:35:28 pm »
I've tried all the different programs and none of them make sense at all  :(
Here is the first exercise from the book:
/* Program 1.1 Your Very First C Program - Displaying Hello World */
#include <stdio.h>
int main(void)
   printf("Hello World!");
   return 0;
Right now I have Visual C++ Express installed (uninstalled the other programs) and when I start it, there is a menu that gives me 8 different things before I can even start the code above  :-\
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #8 on: January 26, 2011, 03:25:26 pm »
oic. that pretty old code pretty familiar to me, why dont you use Turbo C++? thats the oldest i got, version 3 made 1992. if you want a copy, i can provide you, its just 8MB uncompressed, and it run under DOS :o if you want to stick to the newer VC++ Express, there should be a "console app" for that code in supposedly that 8 different things. i use Ms VC++ 6, MPLAB IDE 8.43, AVR Studio 4, and Arduino IDE 0018... for C programming ;)
« Last Edit: January 26, 2011, 03:30:57 pm by shafri »
Offline DaveW
    • WattCircuit
« Reply #9 on: January 26, 2011, 05:00:47 pm »
#include <stdio.h>
int main(void)
   return 0;
You'll want to use the console project option
Offline Markybhoy
« Reply #10 on: January 27, 2011, 04:19:44 pm »
When I was dabbling in C on windows I just used notepad to enter the source code and complied it via the command line.
http://msdn.microsoft.com/en-us/library/bb384838.aspx
Also some good beginner C books are - "C programming A Modern Approach" and "C Primer Plus"
Offline FreeThinker
  • Truth through Thought
« Reply #11 on: January 27, 2011, 05:24:17 pm »
Learning C is a bit like learning to ride a unicycle wearing a blindfold  :D. If you have no programming experience try basic first to get an understanding of program control ie for next, gosub, loop, arrays, variables, goto (ducks  :)), then try C. You will find it is then mainly a matter of syntax in the most part and improving programming habits. You can learn basic without much support C much less so.If you want to try PIC programming you can try the Oshon Pic simulator http://www.oshonsoft.com/. It has a basic compiler and a simulator to run your code free for 30 days
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
« Reply #12 on: January 28, 2011, 11:10:13 pm »
I finally got found something that works thanks to this video:
Offline johnwa
    • loopgain.net - a few of my projects
« Reply #13 on: January 31, 2011, 07:30:13 am »
I would second Mechatrommer's suggestion of Turbo C/C++. I know Borland released Turbo C as freeware, it appears that they have also released Turbo C++ as well. You can get them over here:http://www.uv.tietgen.dk/staff/mlha/download/dos/. While Turbo C is 16 bit, it is fine for learning the language, and it can also be used for 'real' work if you don't mind using a character cell interface. I suggest that you gain a firm understanding of plain C before trying C++ - most programming I have done did not use any object oriented features, and these are somewhat less relevant in embedded environments, etc.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #14 on: February 01, 2011, 01:40:21 pm »
I would be interested to hear if people get Borland / Turbo C/C++ running okay on Win 7. I have the originals (I even still have the manuals!) and it was a superb language and environment for just hacking code together. An order of magnitude faster than Windows environments, even on fast machines.
« Reply #15 on: February 01, 2011, 02:03:31 pm »
I installed Windows XP Mode on my Windows 7 64-Bit, then had the Turbo C Version 2.01 installed on that.
Works no problem that way.
  • Country: my
« Reply #16 on: February 01, 2011, 02:33:18 pm »
the older compiler will not take advantage of and not optimized for newer cpu machine-opcode performance. but newer cpu should be back compatible with old codes. my 2cnts.
Offline Zero999
  • 0999
« Reply #17 on: February 01, 2011, 06:18:53 pm »
Unless it's 16-bit and of course 32-bit programs can't use newer 64-bit libraries.
