Author Topic: Want to learn how to power/control a fan (ebm-papst RV45)  (Read 643 times)
Offline engineheatTopic starter
« on: June 29, 2024, 11:19:57 pm »
Hi
I want to be able to use this fan for a project and be able to control its speed:
https://www.mouser.com/new/ebm-papst/ebm-papst-rv45-centrifugal-fans/
It has some datasheet:
https://www.mouser.com/pdfDocs/RV45DriveElectronicsDatasheet.pdf
But I'm not able to understand it.
I want to power it using 12V, and it states and voltage range of 7-30V, so I think I'm good. But starting on page 4 of the datasheet, they have so many different voltage values it's hard to make sense of it.
It also seems to require their own controller (page 2 of datasheet). Will I be able to control the speed using Arduino (PWM)?
I don't see them explaining what Ubs, Ra, or Us mean.
I hope to be able to understand this fan.
Thanks
« Last Edit: June 29, 2024, 11:23:37 pm by engineheat »
Offline JustMeHere
Re: Want to learn how to power/control a fan (ebm-papst RV45)
« Reply #1 on: June 30, 2024, 12:00:15 am »
The voltage range is 16v to 30v with 24v being preferred.
You control the speed with a 0v-12v signal.  See section 2.1 of you datasheet.
« Reply #2 on: June 30, 2024, 10:27:37 pm »
So that controller with 4 wires is mandatory?
The control voltage (0-12V) goes to wire 3 (Control) and the voltage is linearly related to the speed?
Wire 4 is for tachometer which should be optional correct?
And wire 1 is the voltage to the fan (16 - 30 V), correct?
Thanks
Offline JustMeHere
« Reply #3 on: July 01, 2024, 04:30:01 pm »
No.  Power can come straight from 24v source.
The controller only needs to share the ground, and one signal.  I'd try a digital pot or a DAC.
Yes, but not linear.  See the datasheet.
Yes, it looks optional.
Yes
« Reply #4 on: August 10, 2024, 03:24:58 am »
Hi again,
I have some 18V batteries so I think I will try to use that to power the fan. I don't need anywhere close to full power anyway.
Aside from powering the blower, can I use the same 18V battery to control the speed by using voltage division and a potentiometer to get a variable voltage of 0v-12v at the control? I think the current draw will be minimal if I use high resistance resistors and this seems the easiest way for me.
To get the tachometer to work (I've provided relevant images below), it seems I need to supply a voltage (tacho operating voltage) at wire 4 (U_bs) with a voltage <= 30V. Then, I can count the number of pulses at U_s (tacho signal).
I should be able to use the same 18V battery for U_bs, since it's <= 30V.
U_s has a high and a low. The high seems fixed at 30V regardless of U_bs. The low is determined by resistor R_a, which is what I provide. I need to ensure that the sink current is <=20mA with a suitable value for R_a using the equation they provided.
The datasheet also provides the following schematics with the 10k and 15k resistors. But I think those are internal to the drive electronics and is not something I need to worry about.
Please let me know if I understood it correctly. Appreciate it.
Thanks
« Last Edit: August 10, 2024, 03:26:47 am by engineheat »
