Author Topic: What is the correct name for wire wrapped around a post in vintage hifi  (Read 770 times)
Offline sel_199Topic starter
I was wondering if there is a tool for removing wire connections to the circuit board that are wrapped around a vertical metal post.
I don't know what the correct term is for that type of connection so I can't really seach for a tool.
Does anyone have any information on this thanks.
Offline langwadt
wirewrap ?
Awesome thanks guys.
Online Ian.M
Note that wirewrap used for consumer TV and audio off-board connections typically had a much larger square pin/post and wire diameter than wirewrap used for assembling prototype PCBs, which used thin 30 AWG silver plated Kynar insulated wire (aka: wirewrap wire) on 0.025" sharp cornered square posts, as shown at the Sparkfun link.
The tool *MUST* match the wire and post size.   You *MUST* use a fresh wire end to rewrap a joint - you cant use what ever you unwrapped as the post corners cut into the wire to make gas-tight contact.   :horse:
I suspect you may have some difficulty finding a manual wirewrap tool the right size for the wire and posts in your HiFi. :(
If you don't have the correct tool or enough spare wire length, the standard practice in the repair trade was to re-wind any turns that were insulated + a turn and a half of the bare end and solder it, clipping off the rest, but leaving a slight nub so you can unwind from the end if you have to desolder it.  Once soldered, a post can never be re-wirewrapped.  To avoid this hassle, it may be worth desoldering the whole post from the PCB to avoid disturbing the wirewrap joint(s).  ;)
« Last Edit: May 31, 2022, 12:01:59 am by Ian.M »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
It is indeed named wire wrap and it was typical to be between 22 and 24 AWG.
Such tools still exist for sale, typically more expensive than those ultra-fine wire wrapping tools mentioned by Ian
https://www.amazon.com/Manual-Wire-Wrap-Unwrap-22-24/dp/B004IOQF4E
Again thanks for the information guys, for the odd times I would need it wouldn't justify the expense of such tools.
Looks like solder will have to be the way forward.
Cheers.
