More explicitly, look at using a power op-amp such as LM1875 (3875 for more power), amplifying a voltage reference like TL431. You don't need symmetric supplies for the op-amp, -5V is enough for the negative supply, our use single supply (neg supply is ground) if the output never needs to go below about 5V.
