Loading [MathJax]/extensions/Safe.js
Author Topic: Virtual ground in op amp circuit design  (Read 2127 times)
Offline VinAng0811Topic starter
  • Country: my
« on: August 15, 2018, 08:40:40 am »
Hi
I have simulated 3 circuit in PSPICE. Kindly refer to the attach file.
Figure 1(a), Figure 2(a) and Figure 3(a) are the same circuit. ( a virtual ground circuit, where the output voltage of the op amp = Vdc/2)
so output voltage of the op amp in Figure 1(a), Figure 2(a) and Figure 3(a) is 2.50 V.
In Figure 2 and Figure 3, the output of the op amp (a) and (b) are connected. Based on the simulation result in PSPICE, can anyone explain why the output voltage in Figure 2(b) is 2.00 V and Figure 3(b) is 2.50 V ?
Thank you
Offline mc172
Re: Virtual ground in op amp circuit design
« Reply #1 on: August 15, 2018, 09:14:51 am »
Because in circuits 2 and 3 you've effectively blown up the opamps. Think about what the following circuit is doing:
Also consider how much current you might expect going in or out of pin 6 on both opamps. If you aren't sure, it's on the datasheet for that device.
Then look at how you've connected yours in your circuit.
Offline mc172
« Reply #2 on: August 15, 2018, 09:16:21 am »
Another thing to think about is why circuit 1(b) outputs 4.97 V. Why this number?
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #3 on: August 15, 2018, 09:17:00 am »
Hi and welcome to the forum. You have just learned that Spice simulations are not always useful  ;) . For a start, check output currents of opamps in your simulations and see if these make any sense to you.
Cheers
Alex
  • Country: my
« Reply #4 on: August 15, 2018, 09:25:48 am »
circuit 1(b) the Vin=5V, and the supply voltage of the op amp is 5V, in ideal case the output voltage of a buffer should equal to 5V... why 4.97 V ? because positive supply rail.
  • Country: my
« Reply #5 on: August 15, 2018, 09:31:21 am »
Hi Alex,
I have check on the current... But I still did not understand why why the output voltage in Figure 2(b) is 2.00 V and Figure 3(b) is 2.50 V ?
    • A.N.T. Audio
« Reply #6 on: August 15, 2018, 09:46:40 am »
Hi Alex,
I can give you a clue (just to make you to learn few things) - have a look at the datasheet for the TLV2211, fig 15 and fig 16. Two opamp outputs are competing, one which is stronger is able to control the voltage. These graphs would give you an explanation why the lower out of two possible outputs prevails.
Cheers
Alex
« Last Edit: August 15, 2018, 09:51:43 am by Alex Nikitin »
Online Zero999
  • 0999
« Reply #7 on: August 15, 2018, 10:03:16 am »
Yes, the two op-amps are fighting one another. The one which wins is determined by the current limiting characteristics of the output stage.
In short, figures 2 & 3 are both examples of a bad design.
Try replacing the wire link between the op-amp outputs in figures 2 & 3 with 10k resistors and look at the output voltages and current through the resistors.
« Last Edit: August 15, 2018, 10:05:28 am by Hero999 »
  • Country: my
« Reply #8 on: August 15, 2018, 12:39:15 pm »
Hi Alex,
Thank for your clue.
Based on the Figure 15 and Figure 16, explain why the output voltage in Figure 2(b) is 2.00 V and Figure 3(b) is 2.50 V ?
In Figure 2, the opamp (a) is stronger than the opamp (b) so,  (b) control the voltage.
In Figure 3, the opamp (b) is stronger than the opamp (a) so,  (a) control the voltage.
    • A.N.T. Audio
« Reply #9 on: August 15, 2018, 12:49:47 pm »
Hi Alex,
No. The "stronger" opamp in both cases is the one which sinks the current:
In Figure 2, the opamp (b) is "stronger" than the opamp (a) so,  (b) controls the voltage.
In Figure 3, the opamp (a) is "stronger" than the opamp (b) so,  (a) controls the voltage.
Cheers
Alex
  • Country: my
« Reply #10 on: August 16, 2018, 02:18:02 am »
Hi
Thank you for the explanation.
