Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Function gen output - TTL vs 50 ohm?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Function gen output - TTL vs 50 ohm? (Read 7245 times)
george graves
Super Contributor
Country:
on:
September 26, 2012, 04:40:54 am »
I'm working with a function generator I recently got off of ebay. (FG-8002) I'm playing around with a couple circuits and wanted to use it to test a frequence to voltage converter chip - and also an arduino to measure frequency of a square wave.
It has two outputs. 50 ohm, and TTL.
When is the right situation to use one or the other? And why?
And how much can it drive?
Dave? How about a little "how to use a function gen" video?
Logged
www.digitalunderpants.com
http://hackaday.com/author/georgegraves/
shebu18
Frequent Contributor
Country:
Re: Function gen output - TTL vs 50 ohm?
Reply #1 on:
September 26, 2012, 04:58:23 am »
On the function gen ou can have 10Vpp, so this means a plu 5V and a -5V, this would not work on ttl. On ttl you have 5Vpp and an offset of 2,5V so you get a maximum of 5V and a minimum of 0V on the output.
Logged
ejeffrey
Super Contributor
Country:
Reply #2 on:
September 26, 2012, 08:43:30 am »
The "50 ohm" terminal is the main output of the function generator. The TTL terminal is the sync. It is the same frequency and phase of your output signal, but a logic level square wave. You use it to synchronize multiple instruments. You can send it to your scope trigger input or you can use it with a lock-in amplifier to provide a phase reference.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
