Author Topic: Varifocal lens mount  (Read 326 times)
Offline mr_byte31Topic starter
« on: June 27, 2024, 10:26:19 am »
Hi Folks,
I am trying to make a small project using two lenses as shown in figure below.
I have fixed lens and another movable lens which will go forward and backwards. its movement shall adjust how large is the laser beam on the wall.
it was a nightmare to align the lenses and maintain a certain distance between them.
I have two questions,
1- how can I maintain an accurate measurements between both lenses ex. 2mm ?
2- how to align the center of both lenses ?
is there special tools for that?
I was thinking about building a 3-D module for that but doesn't have any design in my mind that would make life easier...
Offline jfiresto
Re: Varifocal lens mount
« Reply #1 on: June 27, 2024, 10:38:49 am »
You might be looking for an optical bench (Optische Bank).
-John
The following users thanked this post: mr_byte31
Online Phil1977
« Reply #2 on: June 27, 2024, 10:40:40 am »
I assume you are looking for a "kinematic mount". If it´s for private purposes, I´d search on ebay. Else Thorlabs or the other optical stuff suppliers are your friend.
Every time you think you designed something foolproof, the universe catches up and designs a greater fool.
« Reply #3 on: July 01, 2024, 09:31:22 am »
Many thanks all for the comments.
optical bench is a very good solution for experimentation. I didn't know about it. Thx
kinematic mount is my way forward but it is very expensive. I found other options on this page which include many options for lenses mounts.
I am not sure why all optical stuff are expensive and not easy to find.
But your answers definitely helped me.
Offline jfiresto
« Reply #4 on: July 01, 2024, 12:44:20 pm »
You might investigate a less accurate xyz stage (Lineartisch). On ebay.de, I am finding some in the EU, probably Chinese-made, for 110~120 euros.
-John
