I'm not sure any breadboard manufacturer will give you current rating specs, but don't plan to put a lot through one - it's fairly easy to melt the plastic if things get hot.
If you're doing high current work, use a proper prototype technique. Breadboards are really only good for prototyping low speed, low current circuits.
