Author Topic: Why would you put inductive resistors in series with a small electric motor ?  (Read 2840 times)
Offline tigrouTopic starter
This schematic is from the grinder of a coffee machine.
I am wondering why there are resistors in series with the motor. What is the purpose ?
AFAIK It's quite common to add inductors and capacitors to form a LC circuit and do some filtering (to prevent interferences to go back to the electronic part) but there is no capacitor here.
I don't see any resistors.
I wrote resistor because it's written "Ind. resistor" above it and resistors are usually shown as a rectangle.
But indeed there is no "ohms", it's only talking about Henrys and Amps.
« Last Edit: September 02, 2023, 06:50:59 pm by tigrou »
Offline coppercone2
hi, can you put the resistor value of the proposed resistor
because if it dont have resistance then its a inductor
Online temperance
I wanted to expand my comment but instead deleted my post.
There are many ways to filter brushed motors. Sometimes the capacitors are integrated into the motor itself because they need to be as close as possible to the brushes. A combination of some DC resistance within an inductor is not so strange and very of done with low power brushed DC motors like those in shavers, soup mixers,...to provide some damping.
The following users thanked this post: tigrou
Offline TimFox
The label "resistor" must be a mistake.
15 uH at 2 A is a reasonable value for an inductor, and would help filter brush-commutation noise to reduce radiated and conducted EMI through the power feed.
If it were a mistake for 15\$\Omega\$, that would be a physically large resistor that would be rated for > 60 W.
In Europe, the rectangle is often used for resistor, but in North America, it is usually symbolized as a zig-zag, which is a better metaphor for a resistance.
In both areas, an inductor is usually symbolized as a set of loops.
