Is their a difference between Kester and MGchemicals?...I am wondering if their is any big difference.
I used both and to me Kester is noticably better.
I cant find Kester here beside on auction web sites so appears MG dominates in Canada.
As far as the solder, make sure to wipe down the outside to remove contamination and oxides as you use it.
Quote from: David Hess on July 12, 2018, 11:33:07 pmAs far as the solder, make sure to wipe down the outside to remove contamination and oxides as you use it.Hmm I've never done that, I'll have to give it a try and see if it results in nicer joints.
