I have a television with no standby light. When i measure voltages at the input pins of the smps transformer i measure 179 DC volts on two pins. The other two pins are negative, so I assume the voltages on the primary pins of the transformer are good.
When i measure voltages at the output pins (secondary side) of the transformer i get zero volts. If i measure between the ground pins and the other pins i get zero voltage. Is there something wrong with the switching IC on the primary side? Can someone explain why i don't get voltages on the output pins of the transformer. MAny thanks in advance
