Hi everyone,
I am going to build a simple
EDM (Electric discharge machining) system and its circuit schematic is as following:
Capacitor C3, is needed for making coarse EDM cuts. This electrolytic capacitor should be a
photo or strobe flash capacitor. The rating should be a minimum of 100VDC @ 80uf (Schematic and information from: "The EDM How-To Book" by Ben Fleming).
Now, the main problem is that, the mentioned capacitor is not available in my country, so i want to substitute it with an array of parallel normal capacitors that are available for me. I need to know what kinds of capacitors are suitable to be used?
