Author Topic: USB sniffer  (Read 1508 times)
Offline JaneTopic starter
USB sniffer
« on: July 31, 2015, 10:29:14 am »
Can anyone  recommend a good USB and I2C sniffer?
I have USB - I2C bridge ( developement board) and would like to check the data both on USB side and I2C side.
Or how do YOU check the data on USB  that a program sends to?
Offline 6thimage
Re: USB sniffer
« Reply #1 on: July 31, 2015, 02:58:22 pm »
Hardware USB sniffers tend to be very expensive, I have, in the past, used a virtual machine (vmware) and got it to log the USB traffic. But either way, you will end up with lots of data that will take quite a while to process (USB is really quite complicated).
Just capturing the I2C is probably going to be easier - I haven't come across many I2C sniffers, as for most uses a logic analyser (or digital oscilloscope) is more than adequate. The only advantage of a sniffer would be collecting data over a longer period. As far as recommending logic analysers, it really depends on your needs - the open bench logic sniffer is really cheap, but has only a short memory, many people like the Saleae products for a low cost logic analyser, but they aren't cheap by any means. If you give more information on your needs, it might be easier for people to make recommendations.
Offline Matje
Re: USB sniffer
« Reply #2 on: July 31, 2015, 10:34:54 pm »
Ethereal/Wireshark running on Linux can capture and show USB data, provided the "usbmon" kernel module is loaded.
