Hi!
I have MSO1074z with 2.1.4 board and 4.03.SP2 soft. I am trying to open options.
1. Try to use riglol 1.03d Windows: enter the key and get "wrong licence" once. Then, with other codes "licence avoid for 12 hours". I have The same message when send keys by USB or LAN.
What does it mean?
2. Trying to get dump. I have Olimex arm-usb-ocd-h. When starting openOCD:
C:\openocd-0.10.0>bin-x64\openocd.exe -d1 -f scripts\interface\ftdi\olimex-arm-u
sb-ocd-h.cfg -f scripts\target\imx28.cfg
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
adapter speed: 5000 kHz
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_de
assert_srst
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
dcc downloads are enabled
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: imx28.cpu: IR capture error; saw 0x0f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: unknown EmbeddedICE version (comms ctrl: 0xffffffff)
Warn : WARNING: unknown debug reason: 0xf
Warn : ThumbEE -- incomplete support
The board didn't has JTAG pins and I solderer it.
How to set up and use the openOCD properly?
