Found this on Antique Radio's forum. Looks like it's wired right, and by that I only mean the connections are in correct location. I agree with electr_peter, fuse both sides of the powerstat...you just never know, then it's too late. Bullet hit the mark (pun intended) with the cable ties; neatness counts and will save you massive headaches when troubleshooting. steverino also makes a good point about wire color standards (they were adopted for a reason) and securing the line cord. Only thing I would add is to make sure your wiring is the correct size. Some of those wires look small to me (16awg?), which might be ok if it were stranded cable, imo. At least on the output wiring. Tapping off for voltage reading with solid 16ga is fine.
::edit:: If it were me, I would enlarge the hole for the receptacle a bit, mount it on the outside face, and put a coverplate on it as well. Would look very clean.
