If only they were all so easy.
They aren't
ALL so easy, but quite a few are. You've learned a valuable lesson here: switches, connectors, and contacts are frequent sources of trouble in older electronics. A bit of corrosion builds up, and then the pieces of metal no longer make a solid electrical connection when they touch. A lot of failing older devices can be fixed by a generous spraying of deoxit contact cleaner, combined with working the switches back and forth to try and remove the corrosion from mating surfaces. A device with card edge connectors can often be "fixed" by removing the boards from the connectors, cleaning them a bit, and reseating the cleaned boards into the connectors.
Cables that flex are another common source of problems.
Electrolytic capacitors of a certain age will dry out, develop high ESR, and make devices behave badly.
After many decades, old carbon composition resistors increase their resistance by a lot, particularly if they have been running hot.
A good, experienced, repair technician has the skill to troubleshoot in detail, but also has the experience to have a pretty good intuitive feel for the most likely components to fail. Depending on the situation, they might start with a quick and inexpensive fix like spraying deoxit on the switches before spending a lot of time with detailed troubleshooting.
