I've a couple of STM32F103C8T6 bluepill boards that I've so far been programming using serial. I never could get any of the STM32duino-bootloaders working, even after replacing the 10K USB pullup resistor with 1K5.
I received an Aliexpress ST-LINK V2 today and have been tearing my hair out trying to get it to work with STM32CubeIDE. I updated its firmware to V2J34S7 no problem, and the bluepill can be programmed using ST-LINK Utility just fine. It identifies as Device ID:0x410, flash Size : 64KBytes, Device family :STM32F10xx Medium-density.
Trying to debug using the STM32CubeIDE (ST-LINK GDB server) probe fails with
Hardware watchpoint supported by the target
SWD frequency = 4000 kHz
ST-LINK Firmware version : V2J34S7
Device ID: 0x410
PC: 0x80052c4
ST-LINK device status: HALT_MODE
ST-LINK detects target voltage = 3.26 V
Vendor = 0x55
Error in initializing ST-LINK device.
Reason: ST-LINK: Could not verify ST device! Abort connection.
In the log file it shows
readJEP106ID(): Vendor = 0x55 and I'm guessing that isn't ST Micro.
I gave up on ST-LINK GDB Server
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
Switched the probe to (ST-LINK OpenOCD) and then got the same
UNEXPECTED idcode: 0x2ba01477 error as the OP.
Thankfully I found this thread
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I replaced the
set _CPUTAPID 0x1ba01477 as suggested by tsman in the
...\resources\openocd\st_scripts\target\stm32f1x.cfg file and also had to set the generator options to connection speed 4MHz and reset mode to software. Debugging is now working with STM32CubeIDE
I'm also using Visual Studio Code with Platform IO. I had to modify the
...\.platformio\packages\tool-openocd\scripts\target\stm32f1x.cfg file to get that working.
The dodgy bluepill boards purport to have proper STM32 chips. See attached.
