Author Topic: Questions about using Sds 1204 X-E (50 ohm terminiators)  (Read 734 times)
Offline watchmakerTopic starter
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« on: October 26, 2023, 03:22:29 pm »
When it is useful to use 50 ohm terminators at the end of coax when not using the probes?  My generator does output at 50 ohms, but what is the application for these terminators?
Regards,
Dewey
Regards,
Dewey
Online abeyer
Re: Questions about using Sds 1204 X-E (50 ohm terminiators)
« Reply #1 on: October 26, 2023, 06:28:55 pm »
Dave's demo & explanation was here
The following users thanked this post: watchmaker
  • Self Study in EE
« Reply #2 on: October 26, 2023, 08:41:33 pm »
Whoa.  Very helpful.  Did not know about the channel.  I have added it to my learning resources.  THANKS!
Dewey
Regards,
Dewey
Offline TimFox
« Reply #3 on: October 26, 2023, 08:45:38 pm »
Also, note that many (if not most) 50-ohm output generators (function, audio, RF, pulse, arbitrary-waveform, etc.) are calibrated for the voltage across the 50 ohm external load.
With a high-impedance load (such as 1 megohm 'scope input), the voltage will be twice that.
« Reply #4 on: October 27, 2023, 03:16:40 am »
Yes when the AWG is set for 50 Ohm loads.
Not so when its output is set to HiZ, as then the amplitude value the generator displays will match that on the scope display.
