Author Topic: How do you organize all your components?  (Read 9789 times)
Offline amitchell
Re: How do you organize all your components?
« Reply #25 on: February 08, 2017, 11:27:34 pm »
I am using the AideTek Box-All, it works awesome for SMD's. The only downside is that the stickers that ship with them are not very sticky.
http://aidetek.com/mm5/merchant.mvc?Screen=PROD&Store_Code=A&Product_Code=BOX-ALL&Category_Code=Encl
Offline jorgemef
  • Country: pt
« Reply #26 on: October 12, 2022, 04:30:13 pm »
Hello,
For labeling boxes I started using painters scotch tape. Works well, even to grab components together in bundles. :)
Cheers
Offline RoGeorge
« Reply #27 on: October 12, 2022, 04:54:32 pm »
I have tried many, from dedicated drawers to DIY ways.
So far, the winner method was of paper envelopes cut in half, then grouped together in all kind of boxes:
https://hackaday.io/project/6261-new-a-free-lab-organizer/log/20823-lab-organizer-made-out-of-letter-envelopes
Nothing beats that.  Easy access, easy handling almost Rolodex like, low footprint, detachable, easy to reorder/extend or remove values, dirt cheap to DIY more of them in seconds, easy to label or to add later notes on them etc.
« Last Edit: October 12, 2022, 05:00:11 pm by RoGeorge »
Offline Wallace Gasiewicz
« Reply #28 on: October 13, 2022, 11:46:59 am »
I use lots of these suggestions.
I like the envelope one and buy old 3 X 5 card file boxes from second hand stores. Have one for "Resistors" , "1% Resistors", one for "high volt caps" etc...
Works well for thru hole devices.
I like the smd sampler approach also. I make my own clear plastic sheets using a crafting method. You can make any size pocket in a cheap plastic "protector" Works well for  loose leaf sheet size units and make the pockets any size you want. It is just a soldering iron with a roller tip.
https://www.wermemorykeepers.com/shop/tools/power-tools/wr-photo-sleeve-fuse-uk/
Offline Jester
« Reply #29 on: October 13, 2022, 12:47:30 pm »
This is how I organize some of them:
1613395-0
