Okay, I've experienced this numerous times, and I don't know what's happening.
I have an 0603 LED soldered to a circuit board I am working on. When I place my multi-meter on the diode setting and test the LED when it is NOT soldered on the board, it lights up.
However, when I solder it to the board, it does not. So I unsolder it from the board and connect to the multi-meter. It works again.
Why does it not light on the circuit board when the multi-meter's leads are connected directly to the cathode and anode of the LED?
Thanks in advance for your input in clearing up this mystery.
