Author Topic: RC Filter + opamp  (Read 2744 times)
Offline slashguitarTopic starter
RC Filter + opamp
« on: February 04, 2013, 09:01:22 pm »
I'm trying to prototype something similar to Bob Parkers ESR meter with an FPGA, but instead of charging a capacitor with a constant current I am filtering a PWM before applying it to a comparator. The problem is I have 100mV at the inverting input of U2B when PWM is 0.  Any ideas what is causing it and how to fix it?
Thanks
EDIT: Inverting input....sorry for the mistake
« Last Edit: February 04, 2013, 10:55:27 pm by slashguitar »
Offline sub
Re: RC Filter + opamp
« Reply #1 on: February 04, 2013, 09:47:52 pm »
It looks like input offset is your problem---the datasheet lists 12mV max, which would give a 240mV output in your case.  Perhaps either try a different op-amp or build a composite amplifier.
« Reply #2 on: February 04, 2013, 10:00:01 pm »
I'm talking about the opamp on the right(the comparator). Doesn't the input offset appear at the output?(....ex....input is 0 output is 12mV).
I have 100 mV on the noninverting input
Offline IvoS
« Reply #3 on: February 04, 2013, 10:17:12 pm »
If the offset is 12mV with gain of 20 coming from U2A would give 240mV or thereabouts to your noninverting pin of U2B ?? Am I missing something?  ???
« Last Edit: February 04, 2013, 10:21:43 pm by IvoS »
« Reply #4 on: February 04, 2013, 10:54:28 pm »
Sorry, I ment INVERTING input of U2B (VHDL is getting on my nerve :)
That's why it doesn't make sense to me.
p.s. I just measured the noninverting input and its about 20mV (1mv offset is well within spec).
Offline sub
« Reply #5 on: February 05, 2013, 08:54:50 am »
Do you mean the PWM is set to zero, or that there is 0V on the PWM output?  If you have done something like this
assign pwm_out = (counter <= pwm_value0) ? 1'b1 : 1'b0;
then you will get a voltage 3.3*2^(-N), where the N is the number of bits of resolution that you have.  I realise that this is a rather obvious suggestion.  A 3V3 IO would give about 100mV if you had a five-bit PWM.
