I've downloaded the source code for the analog device eval cn0359 eb1z, but I'm still confused about the location of the main program, because if you look at the folder there are lots of source code for each feature of the analog device eval cn0359 eb1z.
do I have to compile all the source code? If so, how do you compile it?
(source code in cpp format)
source code links:https://wiki.analog.com/_media/resources/eval/user-guides/circuits-from-the-lab/cn0359/cn0359-sourcecode-reva.zip
