Instead of choosing between a dodgy Ebay switch mode supply, or decent mains-frequency transformer, you'll have the most obvious choice of buying a modern, decent switch mode supply. I'd recommend looking at Meanwell products available at most distributors. They are maybe 2-3x as costly as the Ebay crap, but safe and reliable, and still not too expensive.
A big question is do you need regulated voltage. If you do, the traditional mains transformer + linear regulator is highly inefficient and also expensive. If unregulated voltage is acceptable (for example, in audio amplifiers), it's already much simpler.
For regulated output voltage, switch mode is almost always the only sane choice.
