Hi everone,
I have a bunch of components here where I have no clue what they are, and a few where I have a hunch what they might be but haven't found anything definitive. So first the mystery components
1. The weirdest one is a potted 3-pin throughhole component (C30355A VC) with a round gray doohickey on top, below are two axial components which based on their label are resistors - however those things are *huge* and partially pretty good precision (e.g. the 3.6 KOhm is specified with 0.02% tolerance). So based on their size and weight I wonder if there is something special about those resistors.
![Help identifying some (likely older) compontents. 2087570-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421844.0;attach=2087573;image)
![Help identifying some (likely older) compontents. 2087534-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421844.0;attach=2087537;image)
![Help identifying some (likely older) compontents. 2087540-2](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421844.0;attach=2087543;image)
2. A throughhole component with a clear casing labled "27 F". I think it might be a kind fuse or maybe an old style diode?
![Help identifying some (likely older) compontents. 2087558-3](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421844.0;attach=2087561;image)
3. Two components which I believe to be 47kOhm Resistor networks. Problem searching for "Rehm" I primarily find welding equipment but no electronics. For the DALE one I found similar ones albeit with more pins.
