Author Topic: TO92 package power dissipation  (Read 7347 times)
exapod
  • Guest
« on: April 27, 2014, 01:59:52 pm »
I'm design a small board and i need to regulate 5V to 3.3V, i was thinking of using the MCP1700 in the TO92 package because i don't have a lot of space. The maximum current on the 3.3V is 200 mA so the dissipation of the regulator is P = (5V - 3.3V) * 200mA = 340 mW . The datasheet says that the TO92 maximum power dissipation is 644 mW. Do you think that the TO92 is a good choice or i should choose a regulator with a TO220 package?
« Last Edit: April 27, 2014, 02:02:45 pm by exapod »
Offline digsys
    • DIGSYS
Re: TO92 package power dissipation
« Reply #1 on: April 27, 2014, 02:10:30 pm »
It will get quite warm, but still in-spec. Make the pads larger, that helps and one "trick" I've used is to -
Use a LDO version of the TO92 with a series 1N4004 diode (Input), to drop another 0.6V and share the heat.
Offline Witention
« Reply #2 on: April 27, 2014, 02:33:02 pm »
TO-92 isn't meant to be a high-power-dissipating package. 180°C/W isn't going to get you too far, and there often isn't exposed metal to help get power out.
Offline David Hess
  • DavidH
« Reply #3 on: April 27, 2014, 08:10:48 pm »
I came up with 380 milliwatts maximum in a conservative design so the TO-92 MCP1700 will work fine.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: April 28, 2014, 06:04:44 am »
You can always use the SOT-23 instead :P
Which isn't as bad as it sounds; with a good solid copper pour on the heatsink terminal (which is... output, I think?), the thermal performance is as good or better than a TO-92, at a fraction of the height.
Seven Transistor Labs, LLC
exapod
  • Guest
« Reply #5 on: April 28, 2014, 11:25:00 am »
Thanks all for the suggestion, at the end i will use a to-220 regulator.
Offline amyk
« Reply #6 on: April 28, 2014, 11:32:40 am »
Datasheet says 131.9°C/W, at 0.38W that's ~50°C rise above ambient... maximum junction temperature 125°C, so there's still a pretty good margin.
