Author Topic: TL866A USB Programmer, what adapter for DIP8 (Winbond 25Q32BVAIG) chip?  (Read 2168 times)
Offline dexvxTopic starter
Hello, my Asus P67 Sabertooth motherboard does not boot (CPU_LED is red on power up). Its BIOS chip is a DIP8 (I think that is the correct term) Winbond 25Q32BVAIG, and I would like to read it to see if it is corrupt. I have a TL866A USB programmer like below:
http://autoelectric.cn/EN/TL866_main.html
The 25Q32BVAIG looks to be 3V (so no need for 1.8V adapter) DIP-8 package (300mil, not sure what that means?) measuring 6mm x 9mm. The datasheet is at below link. However, there does not appear to be a DIP8 socket (or clamp) accessory for the TL866 that fits. I was hoping for someone to point me to the correct accessory.
http://www.datasheetq.com/datasheet-download/853233/0/Winbond/25Q32BVAIG
Thanks
Offline ElektroQuark
    • ElektroQuark
Re: TL866A USB Programmer, what adapter for DIP8 (Winbond 25Q32BVAIG) chip?
« Reply #1 on: October 23, 2017, 07:10:02 am »
The TL866 can read/write compatible devices in PDIP package directly with the ZIF. You don't need any adapter.
DIP8:
« Last Edit: October 23, 2017, 07:17:54 am by EdoNork »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2 on: October 23, 2017, 07:17:03 am »
The TL866 can read/write compatible devices y PDIP package directly with the ZIF. You don't need any adapter.
DIP8:
+1 The ZIF connector is 300/600 mil compatible.
« Reply #3 on: October 24, 2017, 01:26:19 am »
Wow, I feel dumb, I never thought about putting the little guy right into the ZIF.
Looks like the chip reads (as 25Q32BV SOIC8).
