Hello,
I'm trying to build a circuit with an opamp which needs protection from a voltage (27.12MHz) getting too high.
Can I just use a transistor tying both the line in to both the Vcc and Vin, and in the event the Vin threshold is met, the signal will simply go to ground and protect my op amp? Or is there a more elegant solution or component I can use?
