It's a TI 431A part, so I assumed a 4.7uF cap would be adequate. I assume the current IKA in the graph is directly influenced by the value of the resistor I use from the supply to the 431 cathode ?
The TL431, TL432 family of shunt regulators were designed to have wide bandwidth while ensuring stability without any external frequency compensation. This makes the device very useful in a control loop application and as a reference voltage generator without external capacitance.
