I pulled a TL431 adjustable zener from a "broken" PSU, not really sure if the TL431 is still in working order.
I did a diode test between the kathode and anode and that checked out fine, voltage drop on one end, OL on the other.
But I wanted to see it in action in a circuit so I hooked it up like this :
12v ------> 330ohm resistor ----> REF pin
Anode pin -------> GND
Now on the cathode pin I was expecting to see a 2.5v output voltage but that wasn't the case. I was seeing something like 6v.
I then pulled another TL431 from a working PSU and inserted it in the circuit above and voila ... 2.5v output on the pin.
Would that imply that the first TL431 is defective, and what kind of impact would such a component have in a switch mode power supply ?
From what I understand it is used in the feedback circuit together with the opto-coupler and will ultimately control how the switching of the power transistor occurs.
Is it possible that wrong readings coming out of the feedback circuit could cause some issues on the hot side of the power supply ?
