I referred to Cyril Bateman's work earlier - it really is excellent.
I'll mentioned Douglas Self again. Search out "Small Signal Audio Design" and jump to chapter 2.
The important point is that most types of capacitor are pretty linear providing they are not being used to set a time constant (acting as a filter).
With that in mind, it is usual to over-size electrolytic capacitors in audio paths. Just picking a value based on the usual 1/(2piCR) way is not a good idea.
Best practice is to have just one capacitor that defines the -3dB of the whole amplifier, and make sure this is a film type rather than an electrolytic. Having done that, all other capacitors should be at least an order of magnitude bigger than what might otherwise appear to be needed. The aim being to minimise signal voltages across them so that they don't produce distortion. Of course, at higher frequencies the capacitors are hopefully akin to a short circuit, so no voltage is being dropped across them during the signal excursions.
Someone who is not aware of that distortion mechanism could easily assume that the capacitors are unreasonably large for no good reason.
It's easy to test for capacitor distortion if you can measure THD. You don't need a high-end audio analyser to see the distortion from an electrolytic capacitor. Self describes an experiment (page 58) involving a 47uF cap and 1k resistor forming a high-pass filter with a -3dB point of 3.4Hz, which would appear to be pretty reasonable for audio coupling; at 20Hz, the loss is a mere 0.12dB, so you'd think that would be OK given that there is minimal voltage being lost across the capacitor, but there is enough there to cause the THD to be 0.01%. Whereas a 470uF cap is indistinguishable from the AP test system at 20Hz.
As always, one could argue about the audibility of 0.01%, especially down at 20Hz where no sub-woofer will be anything like as clean as that, but once you're aware of the problem and the way to solve it, then few good engineers would be comfortable to leave it alone. A larger capacitor is not all that expensive in the scheme of things.
Self also shows that polyester caps aren't as good as polystyrene and polypropylene, but they are still much, much better than electrolytics, and certainly better than a TL071. This presents a dilemma, but on balance I'd be happy with polyester most of the time. For a top-flight design - which the circuits in this thread are not - then it probably makes sense to fit a polypropylene. No-one will hear the difference, but it's not expensive and doesn't cause other problems, so why not? Marketing will thank you for it
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
