Author Topic: Thermal compound conductivity choice...rule of thumb? Need to do the maths?  (Read 2418 times)
Offline showman
But in this thread we are talking about conduction, not convection. Conduction happens in small spaces where the air is not free to move. Thermal conductivity is a physical constant of air and does not change when the air is in pockets or otherwise. In fact, aerogel has a higher thermal conductivity than air because the thermal conductivity of the aerogel material is greater than that of air. (For example, air has a thermal conductivity of 0.024 W/m-K, while typical solid materials are in the order of 100 times more conductive than that.)
And if you actually click on the link you'll see that the thermal conductivity of that particular aerogel given as an example is 0.005 W/m-K. Much lower than the air's 0.024. This has nothing to do with convection, why even bring it up?
If you have two dissimilar metals in perfect molecular contact (for example soldered or brazed), there is not, in fact, a sharp drop of temperature at the interface. The temperature gradient is smooth and continuous, although there will be a sharp change in the gradient at the interface due to the different thermal conductivities.
It is very well known that the interface itself has thermal resistance, first random work from google https://www.mdpi.com/2073-4360/12/10/2409. Not metal-metal, but the idea is the same.
« Last Edit: October 04, 2024, 08:44:48 pm by showman »
Offline IanB
Very well. I stand corrected. I did not realize aerogels fall into such a special category. See the comment I made before:
If you reach low enough pressures, or small enough scales where the mean free path of gas molecules becomes significant, then different theory is needed, and I am not familiar with this area. It is unusual, and not normally encountered in everyday engineering.
I mention convection, because preventing convection is an important reason for the performance of all air-pocket based insulating materials, including aerogels.
If you have dissimilar materials in contact, like polymer in an injection mold, they are not molecularly bonded (otherwise you would not get the polymer out of the mold). When there is physical contact, but not molecular bonding, then yes, there is an interruption to the heat transfer path at the interface. Granted.
Offline T3sl4co1l
    • Seven Transistor Labs
I mean, there's a small change at the interface between materials -- but it's very small indeed, and microscopic in nature: grain boundaries between crystals, and different types of crystals (e.g. pure iron to brass to copper, etc.).
On a macroscopic scale, these all average out as the bulk conductivity of the material.  You get a very small anisotropy with directional solidification (actually, I wonder how much, for what kinds of materials; I assume it's *something*), more in single-crystal materials (take graphite for an extreme case, ~5 W/(m.K) thru-plane, >2000 in-plane).
Basically nothing to worry about, interface is dominated by the boundary layer (i.e., fill it with grease to be sure), and bulk conductivity and heat equation applies.
Seven Transistor Labs, LLC
Offline showman
This is a strawman argument. There is nothing about getting the polymer out of the mold. It is a simulation paper (i.e. idealistic case) where there is as perfect molecular contact there can be.
I'll copy the image here that actually shows the structure and the temperature plot.
Also the change in this particular case is not insignificant, but almost 100 degrees.
Offline IanB
The paper addresses in great technical detail the same thing that I wrote. I am glad we are agreed.
Offline showman
Not sure about that. First I think you overestimate/emphasize the importance of "bonding". You don't need any attractive interaction to transfer heat. As you yourself pointed out earlier, energy is transferred by collisions (does not really matter if its gas, liquid or solid), so it is the repulsion that matters the most. Yes, attraction matters too, but it is secondary.  Secondly if you believe the same effect occurs at a solder-copper interface, yes we agree, but I don't think you do because "bonding". I'm pretty sure that you are sure that electrical energy reflects at impedance discontinuities, but for some weird reason it seems unbelievable that heat energy can reflect at atomic structure discontinuities.
Non-infinite thermal conduction in crystalline materials like metals occurs (leaving electrons aside for now, but similar arguments as below will apply as well) because phonons which transport energy collide with each other. When they travel inside a solid, the motion is essentially determined by the mechanical, if you will, characteristic impedance of the material, normally called the phonon dispersion relation. This characteristic impedance is different for every material. Now when you put two materials together, even if they bond very strongly, for the sake of argument let's say even more strongly than the atoms within the two materials themselves, there is an impedance discontinuity at the boundary which will reflect the phonons back to the material it came from. The only way to make it more efficient to transport energy across the interface is to impedance match the two materials, but just stronger bonding of the interface does not do it, at least not to the degree that all reflections are removed. In fact very strong bonds (as well as very weak ones) at the interface likely increase the mismatch so there are more reflections (larger temperature drop).
Note that whereas this effect is also real in a solder-copper interface, it can also be somewhat (but not completely) impedance matched, when for example you don't have an atomically sharp interface, but some diffusion of tin into copper/vice versa that makes the interface/material properties variations more smooth.
« Last Edit: October 04, 2024, 10:28:24 pm by showman »
Offline IanB
Thanks for the information about phonons.
I have never delved that deeply into heat transfer at the microscale and the associated physics. There also appears to be a difference between metals and non-metals, with electrons playing a role in heat conduction in metals.
A subject for further reading when I have spare time.
The following users thanked this post: showman
Offline showman
Yes, at room temperature the electronic thermal conductivity is typically much larger in metals than the lattice (phonon) thermal conductivity, but to actually handle that there is really no way around quantum mechanics so things get significantly more complicated. Also because of that complexity I don't know if anyone has done similar calculations as above with both electrons and phonons. Whereas the same argument applies about discontinuities, it could be that the electronic part is less sensitive to that in which case the temperature drop could be even smaller than with the somewhat impedance-matched one for the solder-copper case (but still non-zero).
« Last Edit: October 04, 2024, 11:24:22 pm by showman »
Offline T3sl4co1l
Yeah, phonons are just the quanta of sound (acoustic) waves; the wavelengths relevant for thermal purposes are quite high indeed, and easily scatter, and absorb and emit spontaneously (as you might assume from being thermalized..!), so it's not like you're going to hook up a piezo disc and listen to its temperature; but the physics is the same as regular LF acoustics.  So we can think of it in terms of impedance matching between bulk substances of varying speed-of-sound and density.  (Also, not that these parameters are exactly the LF values either; I believe there's some skew to them, approaching cutoff?  And of course, the upper cutoff is given by, essentially, the mode where every other atom in the crystal is moving oppositely, the spacial Nyquist limit if you will.)
(Which, such a cutoff is obvious enough in solids, and, I believe was sufficient to explain the heat capacity of materials?  But applying the same reasoning was quite the quandry for EM radiation.  Circa turn-of-the-last-century.  The same wavelength vs. degrees of freedom argument, applied to the EM field, leads to the "ultraviolet catastrophe" because there's simply no such limit to the classical EM field: the further up you go in frequency, the more modes fit in a given volume of space, and those modes should all fill equally with thermal energy (equipartition theorem).  Setting an energy-based cutoff, and solving a fairly nasty integral, delivered the black-body spectrum perfectly; but no one quite believed the method, or really understood why it worked.  IIRC, Planck himself disapproved of QM and always considered his trick a hack; mind, this was at a time when convenient hacks were popular in physics, Rutherford's "plum pudding" model, or Bohr's (literal) atomic orbit model of hydrogen, for examples.  It took some decades before we had QM developed well enough to reasonably believe, yeah this weird shit seems to actually be what's going on, and to justify those hacks via direct solution or suitable approximation from the equations of motion, or state.)
Offline showman
I think it happened in reverse order, so Einstein and Debye essentially used Planck's EM theory to derive the roughly correct heat capacity for solids thereby further validating QM. The key for both is not the upper cutoff, but the quantization of energy itself. So for phonons it is the lower cutoff that really matters. I.e. classically they can have as low energy (above the ground state, which classically is 0, but in QM not) as you wish, but quantum mechanically as you approach 0 K the degrees of freedom start to be confined to their ground (lowest energy) states as you no longer have sufficent (thermal) energy to excite those, so equipartition does not hold any more and the heat capacity drops to 0 as opposed to the classical 3kB. Or in other words if you add a tiny amount (below the Planck's constant times the phonon frequency) of energy to a classical crystal at 0 K, its temperature will rise by a tiny amount, but trying to add the same small amount of energy to a quantum crystal will result in nothing. For light I think (but not quite sure) it is roughly the same argument, so at small wavelengths the gaps between energy levels get increasingly large so essentially those degrees of freedom or modes get frozen out as you don't have enough energy to excite those beyond the ground state as opposed to the classical case where the energy is not confined to specific levels.
« Last Edit: October 05, 2024, 02:39:03 am by showman »
The following users thanked this post: T3sl4co1l
Offline helius
The performance of a thermal paste is not only about the R_k of its filler and the amount of oil used. Even if the oil fraction gets reduced to zero, a uniform powdered ceramic like zinc oxide can't conduct heat nearly as well as its bulk solid form, because there is a limit to the density by which uniform spheres may be packed of 63%. To get high performance from a thermal paste, densification must be used, which combines different particle sizes in the necessary ratios to achieve a nearly 100% packing density.
TechIngredients did a good video about this years ago:
Offline coppercone2
small gaps mean thermionic cooling
you might wonder, why are phonons hard to understand? well it was introduced by a soviet physicist during stalin's reign
« Last Edit: October 06, 2024, 10:26:33 am by coppercone2 »
Offline K5_489Topic starter
Good lord....what did I start???  :-DD
Offline Ice-Tea
    • Freelance Hardware Engineer
I feel your pain.
The following users thanked this post: K5_489
Offline 5U4GB
Wakefield 120.  The basic, plain-yogurt, of thermal grease, and only a little less appetizing. (No please, don't actually eat it..)
Just looked it up and, at least from Mouser, they won't ship anything but the tiniest quantity outside the US ("Shipping Restricted / USA Only").  Element14 doesn't seem to stock it, but they have their Multicomp-branded stuff, MPGCS-014, which seems to be roughly equivalent, and the data sheet for it covers all of the characteristics and test methods used unlike most thermal greases which quote a W/mK value and that's it.
Offline bostonman
After reading through this thread, I have a question.
Early on it was loosely stated the grease heats and conducts the thermal heat into the heat sink, therefore an oil could technically be used.
Until now, my thought was that it "pulls" heat away from the part into the heat sink and different types exist that do this better than others.
Does it conduct heat and pulls heat away or does it actually act as a liquid, heat, and the heat sink pulls the heat out of that? I understand the thermal grease fills the gaps between the non-perfect metals (the heat sink and the metal tab of a component), but, as I stated above, I always thought it was transferring heat rather than it heating before the heat is pulled out of that.
Offline TimFox
In this application, heat is transferred by conduction (as opposed to convection or radiation), from the hotter surface to the colder surface.
Therefore, the transistor or IC will be warmer than the heat-sink surface, which will be warmer than the surrounding air.
The grease is one part of the conductive path:  the manufacturer adds higher conductivity powder (e.g., ZnO or Al2O3) to increase the net conductivity of the grease.
Offline T3sl4co1l
"Pulling" implies some active mechanism.  This seems a poor word choice, as there is no heat pump here, only the passive diffusion of heat through materials.
But in the sense of "heat diffuses through it at some rate", yes.  An air gap is terrible; something denser, like a liquid, is an improvement, but the diffusion rate (bulk conductivity) is usually rather low (particularly for silicone oil, heh).  Making the liquid gaps as small as possible (by filling the liquid with granular substances that interlock to some extent, and have high conductivity) improves things even further.
The liquid spaces are far too small, and viscosity high, for convective transfer.
You can always model heat flow as an incremental transfer between infinitesimal shells/layers across the system.  In this case, perhaps (zillions of layers in the component's Si, die attach, Cu bulk, Sn plating), (thousands of layers of alternating oil film and particles), (zillions of layers of heatsink), etc.
In the sense that, compared to an insulator in that place, a conductor "pulls" heat out, I guess, but it's worth emphasizing there's no action here, simply the Fourier heat equation as applied to respective materials and boundary conditions.
Offline bostonman
Probably correct using "pull" is the wrong word.
The reason I used "pull": thinking of just a metal tab of a component and a metal heat sink, the cold heat sink is pulling heat away from the hot tab.
Guess this is a freshman way of thinking about thermal transfer.
In the case of grease (and continuing to use the incorrect term of "pull") I was visualizing the grease acting as a material helping to pull the heat away onto the heat sink. Or does it heat the grease before the heat is transferred to the heat sink?
Not sure if I'm asking correctly.
Offline T3sl4co1l
Not sure if you're asking about steady-state or dynamics (or, that's precisely part of the confusion).
Heat flow depends on the temperature drop across a given volume.  So, the component heats up, which heats up the grease, which heats up the particles, which heats up the heatsink.  No heat flows until the temperature rises, at least by small increment, and so on until equilibrium.
Thermal impedance does depend on the heat capacity of materials involved.  The grease layer of course is very thin so can be ignored for this purpose, but in general everything has thermal mass and conductivity, and therefore some diffusivity which describes the rate at which heat spreads out over time:
https://en.wikipedia.org/wiki/Thermal_diffusivity
There are two kinds of flow here:
Heat flow is a steady-state condition, when one thing is hot and another is cold and there's power dissipated.  The power and temperature values are static, but we still say a power is energy in motion, a flow.  In thermodynamics terms, this is a quasi-steady-state condition, because it's nonequilibrium (heat is still flowing), but nonetheless no variables are changing.
"Thermodynamics" itself is a bit confusing or unintuitive, because what's "dynamic" is the "therm", the heat energy -- not heat power.  Nowadays we mostly use "dynamics" for time-varying systems (e.g. differential equations), so it can seem strange that thermo deals with steady equilibria.  Typical thermo problems consider a start and end condition (e.g., pressure, volume, temperature, energy input/output), and don't care about how the system evolves between those end points, so long as the end points are stable equilibria; or more particularly, that the system can only evolve in specific (and most importantly, continuous) ways between those points, and in such a way that the rate doesn't matter (expanding a volume of gas in a perfectly insulating cylinder, changes its temperature adiabatically, no matter how fast or slow you do it).
The other flow here, is the change of temperature over time; at least when the conditions are first imposed, starting from an equilibrium (say, cold) state.  This involves heat capacity of the materials, and diffusibility and all that.
So that's probably part of the confusion.
« Last Edit: October 11, 2024, 01:46:34 am by T3sl4co1l »
Offline bostonman
Certainly a great explanation.
Maybe I was thinking more on the idea the grease is a "conductor" where it allows the heat sink to "touch" the tab as the tab gets hot. Similar to wire conducting electricity.
Seems more that the grease is touching the tab, so the grease needs to heat before the heat sink sees the heat coming from the tab.
So the grease would need to be made of material that gets hot quickly so it can transfer the heat from the tab to the heat sink. If the grease was say dense dried chalking, then it would take longer to transfer the heat.
Offline IanB
The grease is a conductor, a thermal conductor.
There is so little grease that the time taken for the grease to heat up is insignificant.
Offline T3sl4co1l
I mean, it's both.  They're touching, and conducting heat, so when the temperature rises on one side, it rises on the other side too.
Whereas a dry compound is full of air spaces, and air is bad.  Bulk conductivity principles apply at most any scale, at least until quantum effects come into play.
Offline bostonman
I am guilty of using too much.
I thought more grease meant more heat was transferred but also the extra just squishes out.
Also, I get worried when I smooth the grease because I tend to get scrap lines that remove a small track of grease.
Offline IanB
More grease is more bad  ;D
Consider that either side is a metal surface. The thermal grease is a worse conductor than metal, but is a better conductor than air. So you need just enough grease to fill the air gaps, but no more.
The grease spreads out a lot when you apply pressure to the cooler when you lock it down.
An interesting experiment you can do is to get two glass plates like microscope slides, put a tiny blob of thermal grease between them, and then press them together. It is amazing how far a little dab of grease expands.
The following users thanked this post: 5U4GB
