I guess I could use an LDO, have in the past, but I think because of the difference in voltage it had to work pretty hard and was getting warm. So wanted to go a more efficient route and make the overall supply smaller as well.
But it should still do the correct output voltage though, regardless of load (besides when current limited)?
On that note, I have also removed all the load from the board and the output voltage is still unaffected.
I have tried to keep the active loop small, there is a ground plane for return.
