Author Topic: Flat panel Monitor repair  (Read 773 times)
Offline JamescbarrowTopic starter
« on: September 17, 2020, 12:15:43 am »
I am working for someone that refurbs arcade machines, and he was asking me about doing flat panel monitor repair as he has a lot of them, question is what would be the most common issues besides bulging caps, and issues with the backlight, they are all pretty much computer monitors, using vga for a signal. what tools would I need to do basic repairs, besides a multimeter and a esr meter.
Offline radiolistener
  • Country: ua
Re: Flat panel Monitor repair
« Reply #1 on: September 17, 2020, 01:04:46 am »
screwdriver, tweezers, hot-gun, and soldering station, desoldering pump
« Last Edit: September 17, 2020, 01:07:04 am by radiolistener »
« Reply #2 on: September 17, 2020, 01:22:54 am »
Kinda what I was thinking, am I correct in thinking most of the issues will be bad caps due to failed power supplies.
Offline MosherIV
« Reply #3 on: September 17, 2020, 07:29:59 am »
Hi
Welcome to the forum.
Yes, most commonproblems with lcd monitors is
A. Back light gone end of life
B. Caps gone bad
Other issues
Dry joint on controller chip
Controller chip died.
