Author Topic: The Aneng AN8009 arrived.  (Read 14038 times)
Offline RussTopic starter
« on: January 14, 2018, 07:43:11 am »
  What do you all think of it, as a cheap  meter? I do not want to be hauling the Eevblog/Brymen 235 around.
Thanks
Russ
Offline soubitos
  • Country: gr
    • I sell on Tindie
Re: The Aneng AN8009 arrived.
« Reply #1 on: January 14, 2018, 08:25:52 am »
I got ANENG AN8008 and am quite happy with it.. i had to replace the fuses with SMD ones at some point but besides the obvious and expected issues of such a cheap product, it does the job, and serves well....
« Reply #2 on: January 14, 2018, 03:36:27 pm »
   SMD = ?
Offline jeroen79
« Reply #3 on: January 14, 2018, 07:11:28 pm »
   SMD = ?
Surface mounted device?
The following users thanked this post: Russ
« Reply #4 on: January 14, 2018, 09:09:57 pm »
   SMD = ?
     They sure are tiny in size?
Russ
Offline soubitos
  • Country: gr
    • I sell on Tindie
« Reply #5 on: January 14, 2018, 09:39:23 pm »
They sure are :)
Offline Electro Detective
« Reply #6 on: January 14, 2018, 11:27:23 pm »
Great idea   :clap:  assuming the SMD fuses can suppress the BANG! properly
and not become a flashover fast bridge to multimeter hell  >:D
Still, there's lots of room left in there for spares, and toothpicks to pry them out   ;D
Thanks
Russ
I'd feel more secure and confident lugging the heavier 235 around and get a free pump,
you never know where DIY probing can take you sometimes  :-//
« Last Edit: January 14, 2018, 11:37:17 pm by Electro Detective »
Offline ez24
  • L.D.A.
« Reply #7 on: January 15, 2018, 08:27:18 pm »
Thanks for this post - I had no idea my meter had SMD fuses (I did not know they even existed).  Now to order some   :-+
Offline ez24
  • L.D.A.
« Reply #8 on: January 15, 2018, 08:50:21 pm »
Now I am confused
https://www.markhennessy.co.uk/budget_multimeters/aneng_an8008.htm
Shows 10mm fuses
Could it  be the posted picture with the name 8008 is really a 8009 ?
I guess I have to open my "8" and order a "9" and some SMD fuses just for the hell of it  :-DD
What is the real scoop?  I have a handicap - I have "fuseritis"  this is a disorder where I blow too many fuses
thanks
« Reply #9 on: January 15, 2018, 09:14:04 pm »
Now I am confused
Shows 10mm fuses
thanks
They are the tiniest fuses that I’ve ever seen (Aneng 8009)
Russ
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: January 15, 2018, 09:24:31 pm »
SMD fuses are common in the boards I use for work - they are certainly tiny but quite useful.
One interesting tidbit: Littelfuse rates them up to 250VAC with an interrupt rating of 100A. However, if you use your meter up to 86VDC, it shows a rating of up to 10kA - same rating when compared to the multi-dollar Bussman fuses used by Fluke! :-DD
http://www.littelfuse.com/~/media/electronics/datasheets/fuses/littelfuse_fuse_476_datasheet.pdf.pdf
Offline Mark Hennessy
    • My electronics and audio website
« Reply #11 on: January 15, 2018, 09:32:21 pm »
Now I am confused
soubitos modified his meter. They come with 10mm fuses from the factory.
« Reply #12 on: January 15, 2018, 10:08:05 pm »
3.5 x 10mm in size. Cylindrical in shape.
« Last Edit: January 15, 2018, 10:11:12 pm by Russ »
Offline ez24
  • L.D.A.
« Reply #13 on: January 15, 2018, 10:43:19 pm »
Now I am confused
Thanks I was getting confused which is easy.
I opened my 8008 and found the 3.6 x 10mm 10a fuse in a fuse holder.  So I looked to buy some and the only reasonable ones come with leads.  I ordered 100 for $7  and will cut the leads off.  Other wise they are over a buck each.  Regardless I am glad for this post to remind me to get extra fuses.  I do low voltage stuff so I feel that I do not need ceramic fuses (the one dollar ones).
Reading around forums, it seems I am not the only one to get confused.   :phew:
Offline soubitos
  • Country: gr
    • I sell on Tindie
« Reply #14 on: January 16, 2018, 12:23:02 am »
Now I am confused
Oh, i am sorry, i didnt think noting i did change the stock fuses with SMD ones... i did so because i needed to replace the 250mA fuse with.. something... and i did have the SMD fuses lying around.... when i noticed the SMD fuse HOLDERS would fit perfectly in the position of the stock fuse holders it was a very easy decision.
I am very happy with the ANENG meter... i didnt like to order the same fuses it came with first because as said above, you can only find those with leads and second because you really dont know what those are good for right? While on the other hand, littlefuse parts are well known and good quality so why not? They come at a cost but they are not expensive either ....
Offline ez24
  • L.D.A.
« Reply #15 on: January 16, 2018, 01:03:27 am »
Thanks I am going to look into SMD fuses.   :-+
« Reply #16 on: January 16, 2018, 02:16:19 am »
I am still a bit unclear as to what SMD fuses are? I think that the OEM fuses are dirt cheap from Platt’s.
Russ
Offline IanB
« Reply #17 on: January 16, 2018, 02:47:28 am »
There is a picture in Reply #5:
Offline Alex Eisenhut
  • Place text here.
« Reply #18 on: January 16, 2018, 02:55:08 am »
I hope it has a better rotary selector switch than the landfill-grade one they used on the AN8008.  >:(
Offline amspire
The following users thanked this post: ez24
« Reply #20 on: January 16, 2018, 03:51:45 am »
Mine in the Aneng 8009 are small and cylindrical in size.
Russ
Offline IanB
« Reply #21 on: January 16, 2018, 04:04:24 am »
Yes, we know that. But the person who posted that picture replaced the original cylindrical fuse holders with SMD fuse holders and fuses.
You asked what SMD fuses are. The picture above shows an SMD fuse in an SMD fuse holder. They say a picture is worth a thousand words. So why are you asking for so many words to explain what is so clearly shown in the picture?  ???
« Reply #22 on: January 16, 2018, 04:14:30 am »
What is the purpose of replacing originals with SMD’s?
Thanks
Offline IanB
« Reply #23 on: January 16, 2018, 04:19:57 am »
See Reply #14  ::)
Offline ez24
  • L.D.A.
« Reply #24 on: January 16, 2018, 04:51:56 am »
Is the SMD fuse  1808 ?
I like this idea
