P.S: Sorry about mixing up my words of constant current and current limit! I called it constant current because that's what the buck converter can say it does!
Common newbee mistake. Most buck/boost converters can be used in either Constant Voltage OR Constant Current mode.
They CANNOT do both at the same time.
Your description did not make it clear that you are using buck converters.
To use buck converters as CV, you take the output V and feed it back to the controller sense via a voltage divider (eg a potentiometer).
I would suggest looking at the design I posted for how to add current limit.
It works by using a current shunt (accurate low ohm resistor) and comparing the current output against a set limit.
If the current output reaches or tries to go over the set limit, the op-amp starts to try and drive the output voltage down - there by maintaining the current limit.
In order to make this work with the buck regulator, you will have to do a similar ORing arrangement with the set voltage ( the feed back to the controller sense )
Never done this before, so good luck
