Hi
Here is the situation: I am using a piezoelectric sensor which generates analog signals like these two attached (showing lowest and highest + imagine anything in between). Lowest is about 4Vpp and highest 50Vpp.
My board is running at +3.3V.
I do not care about the actual signal, I just want to send it to a MCU and digitalize it:
1 = there is a signal there (say above 4Vpp), 0 = there is not.
The MCU input can be an ADC or comparator input.
I am guessing the 50Vpp signal would actually damage the MCU, so the signal needs to be contained before being sent to the MCU.
How would you do that, without using a complex analog circuit (like a boost converter and an opamp)? I was thinking maybe adding some diodes to clip the signal?
Thank you!!
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
