If a crystal oscillator - for example a common 4-pin 3225-package 32.768 kHz oscillator - has specified a startup time of a few milliseconds, what exactly defines "startup"?
What I mean is, is that the time it takes from power-up (i.e. power applied to VDD pin) for the output to be stable? Or is that the time it takes the output to be stable after the 'enable' pin is activated? None of the datasheets I've seen specify exactly.
I suspect it's the former, but I'm not sure.
Also, another question: what would be the point of having an AC-coupling cap, for instance 100 nF, in series with an oscillator's output? I have seen a reference design with this. It would seem to serve no purpose to me.
