I have a 24v product that is essentially an intelligent power switch with 5 connectors on the output. A microcontroller monitors voltage and load. A PowerProfet load switch from infinion is used as the switch to the outputs. All 5 outputs are tied together to the load switch. The maximum current is 9 amps.
There are a number of difficult solder connections and crimp connections that I would like to have load tested after the PCB is assembled into its enclosure.
What I would like to do is build a test setup that can do the following:
- Calibrate the ADC and voltage divider resistors on the product being tested
- Calibrate the current sense function of the Profet power switch
- measure the voltage drop across the device under maximum load (To test for any issue with components on the PCB)
- measure the resistance of the 5 outputs individually (to test for a bad solder or crimp connection)
What I am proposing is to build a test device that can switch the input of my programable load between the various outputs of the device being tested. I would basically build a MUX using a pair of MOSFETs for each output and then have a multichannel ADC that would measure the the voltage at the following places:
- Input to the device tested
- output of device before the 5 connectors
- output of each connector before the MOSFET MUX
This would be controlled by a microcontroller or maybe a raspberry pi. The controller would be isolated from the MUX, ADC, and device being tested.
I realise I would need to calibrate out the resistance of all the wiring from the device being tested to the MUX and Programable load.
Questions I have:
-Does this seem like a reasonable approach or am I missing something conceptually?
-Would It be advisable to measure both the positive and negative seperatly at each connection? Or can I assume that if there is an issue with the negative side of the connector it will show up when I measure the positive side?
- What kind of protection might I need for the MUX, ADC, ect (maybe this is too broad of a question)?
Nothing is designed yet so I’m just trying to brainstorm possible ideas here.
Thanks!
