- The via above R4, cuts the top side ground plane, leaving an island below and to its right. This island is connected by a via, so it's not floating, but it can't carry any direct current.
- Instead, move R4 via down to that location. This greatly shortens the slot area on the back side.
- Likewise, a shorter path for C4-2 to U1-2 is preferable. This can be routed entirely on the top side, which will remove one spoke to U1-1 and I think two GND vias (the top two between C3 and U1), which is paid for by having solid ground under U1.
- What type inductor? Cutting out ground under it is almost always dumb, it's... silly that appnotes even quote that. In particular, shielded types basically don't care. Air core types are the most likely offenders, and not even for reasons that are applicable here -- namely that Q and L drop due to proximity of metal, and this not being a precision RF application, those don't matter very much (the drop might be <10%). Q does affect efficiency, which is a good reason to use a cored type (at 500kHz, air core has much poorer Q). And the best part, the whole issue is moot when using a shielded type, and they are readily available in this size.
- Move C3 to the, basically the exact opposite side of L1, over by D3-R3. This reduces output loop area, and in particular, input-output area. Filtering is best when it is point-like, so reducing the loop area between VIN, GND and VOUT improves noise. (This is a free improvement, though it probably won't amount to much. Additional LC sections can be added to both VIN and VOUT, extending the bottom edge as needed, to improve EMI further.)
- You may find it's worthwhile to cut some thermal spokes to U1 pads. I've already mentioned U1-1 for another reason, and U1-3 may also prove difficult to solder.
- Also, D3-1 and R2-1 could have one spoke, and C1-C3 and D2 could have two spokes (probably the horizontal pair?).
- This doesn't matter much for reflow soldering, nor for 0805+ size chips. It may prove helpful for hand soldering (iron), and balancing pad entry is recommended to prevent tombstoning on smaller (0603-) chips.
- EN: it's not obvious that their method is even a good idea. The block diagram shows a protection diode (but is it also a zener, or what?) and a pulldown resistor (evidently a bit under a MΩ), and an abs. max. rating of only 6V. A 100k pull-up will surely cause zener breakdown or something, but is this intended? No I_EN limit is given, we must assume (nearly) zero. So, the datasheet is contradictory.
- Anyway, threshold is reasonably precise, so it can be used for UVLO. Preferred solution: use a voltage divider to set a minimum input voltage, probably 6-7V would be fine here. Then at 12V supply, V_EN won't be more than 3V, nice and safe. (And then of course you can fit whatever resistors work. 75k pulldown and 220k pullup would be alright I think. Or, 75k up and 25k down, and then maybe R1 can be changed to 25k and R2 to 4.7k?)
- Also the 75k resistor in the first place... weird, they actually show internal compensation components. And it's transresistance mode, i.e. the FB pin is the summing node of an inverting amplifier so input current is converted to output voltage (hence, a gain with units of resistance). At least at AC, of course. So, that 75k sets the input current, and so the gain (and the dominant pole, but not the zero).
The feedback network could presumably be rearranged, so that the 75k is lumped in with Thevenin(R1, R2), and the (external) zero is about 82k + C5, wired between VOUT and FB. That is, from what's shown: R5 is shorted out; R1 and R2 are increased; and C5 has ESR added to it (really, just moving R5 over there).
That wouldn't be exactly the same transfer curve, but it would be close enough.
I guess it doesn't really matter, they just chose an unconventional equivalent. So it looks weird, but it's actually fine. (This isn't a recommendation, just explaining.)
- The boost network is similarly poorly documented. No internal connection is shown to the high side driver supply, so it's just floating..?! Obviously they must have something in there and forgot to show it. And why show 1uF (on the application circuit) when 10nF will do?
- Efficiency and inductor DCR: well, they did say "for highest". Compare to Rds(on) of 80/160mΩ, so, well, yeah. Anyway, at a mere 5W output, you probably don't need every last teensy percentage point, you can afford a few tenths of a watt, it's not going to matter.
- Inductor value: Staying towards the low side, I think is probably better. If you choose a higher value, beware that compensation values may change (R5, C5), and instability may result at high currents, regardless of compensation -- even with slope compensation, peak current mode control will only operate down to a certain ripple fraction, below which it breaks into chaotic behavior. This operating mode isn't fatal, but acoustic noise (hiss) appears and output ripple increases; it's not preferable.
Aaand, that covers basically every possible thing. Most of these are small, trivial changes, that take less time to do than to even read. A spec on noise level would be nice, to determine position of bypass capacitors and whether more filtering is needed. A better datasheet would be nice, to have design assurance of operating conditions and component values (and being able to calculate compensation would be nice). So there may be some iteration in testing, but the starting point should be close so this won't take much time.
