But in the circuit I sent a link for, I used it in low-side.
If the dropout you guys know about is in the datasheet, I'd really appreciate it if you tell me where exactly that's hidden.
It won't be on the datasheet explicitly since the dropout is related to circuit implementation. For simple current source/sink, a BJT need to drop at least a V
BE although it's more common to use 2*V
BE, a MOSFET need to drop at least a V
GS(TH), a linear regulator need to drop at least a V
REF.
You can get lower dropout by using amplified current sense and/or lower reference voltage, but that won't be "simple" anymore. Some switching converter optimized for constant current (LED drivers) also have very low V
REF (usually something like 0.2V) specifically to reduce dropout.
In my opinion, I don't think dropout is even a problem here since you're using it to charge a capacitor, where the current will taper off to zero and the dropout will also be zero.
