Loading [MathJax]/extensions/Safe.js
Author Topic: suitable scope to use for RF work  (Read 27040 times)
Offline jason695Topic starter
« on: September 28, 2011, 07:31:59 pm »
hi anyone,
i hope this doesnt seem to broad or vague a question.
can anyone answer my question about a suitable dso if any.
i am trying to do some RF measurement. it will all be done on unmodulated sine waves. i was looking ultimately to measure a 100 mhz sine wave. however, most of my work will be done at about 30mhz.
the only problem is significant parts of my study is being done on single transistor oscillators designed and constructed by me. these are simple sine wave oscillators e.g. colpitts, hartley etc. im not using premade square wave clocks etc.
in this situation obviously there'll be more significant harmonics than from signal generators or premade i.c. but, more importantly i think, there'll might be distortion as in "squashed sine waves" to some extent.
obviously the DS1052e is only 50mhz banwidth but, it is 1ghz sample rate so although attenuated it can theoretical measure 100mhz sinewaves. i know about nyquist etc but, would such signals be heavily aliased & what about limited bandwidth of 50mhz.
can anyone tell me if the ds1052e would be suitable with all these effects present.
thanks everyone
jason
alm
  • Guest
Re: suitable scope to use for RF work
« Reply #1 on: September 28, 2011, 07:38:35 pm »
Sounds like you need a spectrum analyzer, not a scope. A scope is only useful to establish the presence of an RF signal. It will lack the bandwidth to show much of the harmonics, and FFT is a lousy replacement for a real spectrum analyzer due to very limited vertical resolution.
Offline gregariz
« Reply #2 on: September 28, 2011, 08:29:51 pm »
I regularly use both specans and scopes for this type of work. The scope is a useful tool to look at things like clipping and waveform shapes that give one an idea of circuit function and design problems. I would suggest you find a 100 or 150MHz scope if your intention is to look at the higher frequency. Regardless of which scope you buy it will have a higher frequency rolloff that will result in any higher frequency components either being missed or distorted.
alm
  • Guest
« Reply #3 on: September 28, 2011, 09:35:02 pm »
For 30MHz signals a 100-150MHz scope may be OK. For 100MHz, I would recommend a 500MHz scope if you want to measure the shape as the signal, and not use it as a clumsy frequency counter / power meter. Note that the scope bandwidth is the point at which signals will be 30% down in amplitude. It will have a hard time displaying anything but an attenuated sine at its rated bandwidth.  Any signal except perfectly sinusoidal signals will have a larger bandwidth than just the fundamental frequency.
Offline vk6zgo
« Reply #4 on: September 29, 2011, 04:55:02 am »
Obviously,a Spectrum Analyser would be nice,but it may be outside your budget.
As far as Oscilloscopes go,I would suggest you look around for an analog 'scope,as you may be able to get a 400MHz one reasonably cheaply.
Unless your sinewave is severely mangled,the level of any harmonics above the 3rd, probably won't be too high so 400MHz BW would be fairly useful.
If you already have a DS1052e,then try it & see what happens.
Other than a Spectrum Analyser,there are other & sometimes more useful ways than looking at waveform distortion to check for harmonics of a sine wave,such as:-
(1)
Absorption Wavemeter ( basically a tuneable detector--you tune it for the suspected harmonic).,
These are very old technology now,you might find one on EBay,or you could make one!
Commercially made ones have a calibration chart,so you can set the fundamental as 0dB,& read off the amplitude of harmonics in dBs down.
(2) VHF/UHF receiver---obviously,these won't give you an accurate measurement,due to AGC,etc,but they will indicate the presence of a harmonic.
This is all presupposing a limited budget.If you can spend around $1600 you can pick up a brand new Chinese Spectrum Analyser which should make things quite easy.
VK6ZGO
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: September 29, 2011, 09:43:41 am »
my way. not how it supposed to be... Observing 433MHz RF signal using 100MHz Scope (DS1102E)
Offline vk6zgo
« Reply #6 on: September 30, 2011, 05:13:00 am »
Where are you looking at?
Simple Amplitude Modulation gives an output which includes:-
 fc =the RF carrier frequency---433MHz in this case
 fm=the modulating frequency ----837kHz?
 fc-fm or 432.163 MHz
 fc+fm or 433.837MHz
All these frequencies will be present at the output of the modulator or modulated stage.
It is necessary to restrict the bandwidth after the modulator using a bandpass filter (BPF),or high pass filter (HPF)to remove the unwanted modulating signal  fm.
From the look of the waveforms presented,it seems that the probe is placed prior to any filtering,so that the modulating frequency is the major component of the signal.
What do you see with the RF turned off?
What do you see with the modulation turned off?
VK6ZGO
Offline joelby
« Reply #7 on: September 30, 2011, 05:39:29 am »
Yeah, you're really not going to see any of the 433 MHz signal on a 100 MHz scope using a 150 (?) MHz CRO probe. Anything you do see is probably noise.
If you wanted to observe the RF signal, you could mix 433 MHz down to a low IF (e.g. 10.7 MHz) using a 422.3 MHz local oscillator.
  • Country: my
« Reply #8 on: September 30, 2011, 05:56:57 am »
err (biting my nail)  :-X
What do you see with the RF turned off? = 10kbps pwm signal (feed to radio)
What do you see with the modulation turned off? = 433MHz signal (i suspect) from the spec. i'm not able to make the stable signal, its premade and only modulate when pwm goes hi->lo
you are right, there's no filter at all, except DC filter. i'm using premade rf module, use as is, no filter.
my point is not filtering, i know i can see some spike/noise there but, i only care the carrier signal (thick line below the "distorted pwm" shape)
« Last Edit: September 30, 2011, 06:05:25 am by Mechatrommer »
  • Country: my
« Reply #9 on: September 30, 2011, 06:01:30 am »
yea maybe you are right. but in the link i've provided the noise level (no signal) and the ~433MHz "noise" when i punch in the signal and calculating/estimating the "noise" freq.
i guess you and vk6 are refering to FM radio?
  • Country: my
« Reply #10 on: September 30, 2011, 06:06:49 am »
as i said... not how it supposed to be. buy a spectrum analyzer! that how it supposed to be.
Offline joelby
« Reply #11 on: September 30, 2011, 06:07:55 am »
It's still effectively noise, since you don't know if it's really a 433 MHz carrier, part of the modulation, aliasing, outside RF being picked up by your test setup, etc. If you have a signal generator, you can try observing the output of that at 433 MHz on your oscilloscope to provide a comparison of a clean, unmodulated signal.
Nothing that sophisticated - if you mix 433 MHz with 422.3 MHz, it will be down-converted to 10.7 MHz (plus a bunch of image frequencies, but 10.7 is a convenient frequency that you can see on a 100 MHz scope and filter with a cheap filter). I suppose the question to ask is exactly what you're trying to observe here.
Offline amspire
« Reply #12 on: September 30, 2011, 01:40:33 pm »
It didn't make sense that the Rigol couldn't show a 433MHz waveform, unless the trigger didn't work at 433Mhz.
My first CRO was 5MHz analog and I used it all the time to look at 20MHz+ waveforms.  OK the amplitude was low, and it was useless at waveforms,but it displayed the signal fine.
I just tried it on a DS1052E that was upgraded to 100MHz. The best source I had at hand was a 433MHz transmitter, and the signal was pretty messy and there was a lot of background noise, but the trigger was rock solid at 433MHz and the waveform is fine.
Here it is:
I used the 25GS/a Equivalent Sampling, and as long as you can trigger off a repetitive signal, it should show a real waveform at only 433MHz. That A/D's gate time is well below 1nS so it can capture 433MHz easily.
What I found is that the FFT works fine (it was working better earlier, but this evening, the background noise has gone right up). If you stop the trace on the oscilloscope, it only shows a single shot capture (rather then Equivalent Sampling), but if you press the Stop in the control box on Ultrascope, it freezes the Equivalent waveform.  I don't have the Rigol probes on hand, and I used some really crappy 100MHz probes instead. I will dig up the Rigol ones tomorrow. I might also try a 500MHz probe and see if it make a difference.
Richard
« Last Edit: September 30, 2011, 02:17:00 pm by amspire »
Offline amspire
« Reply #13 on: September 30, 2011, 02:47:40 pm »
A bit clearer with a  500MHz probe. Still masses of noise as I can't get a decent ground near the antenna.
The 433Mhz signal is definitely there. Be much easier with a decent signal of known amplitude to test, but I think the highest I have from a generator is 150MHz.
Richard
« Last Edit: September 30, 2011, 02:51:39 pm by amspire »
  • Country: my
« Reply #14 on: September 30, 2011, 04:06:26 pm »
i dont think its the noise. i highly believe its because the equivalent sampling method, or sampling jitter or such, maybe. your FFT is clean, and wait... you turn ON the FFT? max is 500MS/s, violating Nyquist rule. just an assumption. since you have astable 433MHz source, why dont you try my setup... fft off,ch1 only, real time sampling. try both sinc(x) on and off. i'll be thankful if you can show the picture here.
Offline amspire
« Reply #15 on: September 30, 2011, 04:26:47 pm »
It is noise - lower frequency . I know - I had to set the trigger as high a possible to trigger on the peak of the LF noise.
Nyquist has not been violated as equivalent sampling is real sampling for a repetitive signal.
So the sampling rate is 25GHz. It is not 1GHz . There are over 50 measurements per cycle evenly spread across the cycle. Until recently, sampling was the only way to view microwave waveforms.
Back in the 60's, you could get a 30GHz sampling scope, even though the scope mainframe could not cope with more then a few MHz of bandwidth.
Richard.
« Last Edit: September 30, 2011, 04:51:39 pm by amspire »
  • Country: my
« Reply #16 on: September 30, 2011, 06:38:41 pm »
the first time i've heard. yes, that was my suspicion, your 433MHz is not a clean/pure sine wave.
Offline amspire
« Reply #17 on: September 30, 2011, 08:37:04 pm »
The noise is there with the transmitter unpowered. As far as I can tell, the waveform I'd clean.
You still seem to believe that the Rigol cannot see a 433MHz waveform.
It definitely can. It is definitely not an aliased fake waveform.
I have another transmitter at 310 MHz and if I connect it I see 310MHz.
Are you suggesting that the Equivalent Sampling on the Rigol does not work?
Richard
  • Country: my
« Reply #18 on: September 30, 2011, 09:25:13 pm »
how can you make this conclusion? rewind to reply #5 in page 1. i'm with you ;)
no. i'm suggesting, your transmitter signal is not clean. which is you've already admitted.
i've used equ. sampling and it can better show higher frequency signal, ie near or higher than the scope BW. its just we have to grasp the experience of what the jumbling shape is. its your signal mixed with other freq components, as you said, low freq one. you can call it jitter(ing) or interference, but not noise. noise is alot higher freq than your signal and is random and alot low magnitude. will be difficult to distiguish between noise and harmonics (or freq components) in eqv. samp. mode. but i've seen the picture similar to yours while i was observing non-clean 75-100MHz signal in eqv. mode. if its noise, then your picture should be alot cleaner and less jumbling. but if your signal is near noise level, then it will be alot jumbling and probably you wont see anything meaningfull.
« Last Edit: September 30, 2011, 09:50:26 pm by Mechatrommer »
alm
  • Guest
« Reply #19 on: September 30, 2011, 09:47:37 pm »
So what does it tell you about the signal? Does it show the amplitude (minus how many dB)? Can you determine the frequency with any accuracy? Can you tell distortion? Harmonics? How is this better than a frequency counter or RF detector probe which will easily go to 500MHz for less money that even a 50MHz scope? At least these are specified for those frequencies.
Sure, if you feed it a ton of signal, some will make it through. It's hardly a measurement anymore, though.
  • Country: my
« Reply #20 on: September 30, 2011, 10:08:19 pm »
as in my link in reply #5, we cannot measure it accurately, quantitatively speaking, but at least we see something persistent. if i want to build a high quality 400MHz signal, then i need to see if it has 4GHz component which is far from impossible using 1GS/s scope. but let say we are working on 40MHz signal, then we may have an idea what the noise/harmonics of the signal up to its 10th harmonics, but as i said, its amplitude is not accurate since i dont have the scope profile. if i'm one of rigol staff, then i may want to steal the profile from the engineer and do the diy compensation.
i never heard freq counter that can show many freq. or i'm not familiar enough with it. showing only one frequency will not be helpful in (mixed) signal analysis. if hi freq RF is thy main stuff, thy feed and thy shit with it, then thy should get a spectrum analyser, or maybe VNA? not sure.
Offline amspire
« Reply #21 on: September 30, 2011, 10:21:08 pm »
It says a lot. Yes you can use a rf probe and it gives you a different set of information. The frequency attenuation will be something that can be measured and then you can compensate for it,so yes you can get amplitude.
Definitely you can spend a lot of money buying better gear, but it is good to learn the limits of equipment too. The Rigol provides very useful information above 100MHz.
I would hate to suggest to someone that they couldn't do rf work because they only had a Rigol scope.
Richard.
alm
  • Guest
« Reply #22 on: September 30, 2011, 11:26:20 pm »
You may be able to get a ballpark estimate. I wouldn't expect the attenuation to be very linear over the vertical sensitivity range or maybe even other factors like vertical position or individual channel. You're characterizing something that even the manufacturer didn't bother to spec. You're also presenting a fairly low-impedance load to the signal source with a 10Mohm passive probe (about 30 ohm), something that will load down the signal.
How would you calibrate it? You'd need access to a fairly clean signal source of known flatness that spans the 50-500MHz range. Or something else to measure the power/amplitude accurately.
It provides some information. Basically that there is a signal that includes a frequency component around 433MHz. It may also include other frequencies. It may even be a 433MHz square wave. Granted, it's infinitely better than no information. But it's not very detailed or reliable information.
I wouldn't suggest that either, you can even do RF without a scope (it just gets a lot harder), but suggesting that it's a good buy to observe signals near or above its rated bandwidth isn't correct either. It may be usable in a pinch.
Offline amspire
« Reply #23 on: September 30, 2011, 11:46:19 pm »
Alm,
Basically I think we probably agree. Absolutely if you can have 4GS/s oscilloscope and a wideband spectrum analyser - fantastic. From where I am coming from, I just hate the idea of not trying something because you don't have the right equipment. When you have to do something and you don't have the right specialized piece of equipment - you have to be creative and that's fun.
I bet the person who designed the first spectrum analyzer would have loved to have a  .... spectrum analyzer.
Richard.
  • Country: my
« Reply #24 on: October 01, 2011, 03:14:00 am »
From where I am coming from, I just hate the idea of not trying something because you don't have the right equipment. When you have to do something and you don't have the right specialized piece of equipment.
vote with both hand ;D i know i need to have a SA, but i know i cannot afford it, and maybe, this is the only time i'm playing with RF, so is it worth it? dont i have the right to play around?
i dont thing so.
