There are a number of typos between this spice figure and the hand analysis shown.
Examples-
RE1 is 7.5K in the spice circuit and netlist but the author uses 5.57K in his hand analysis.
- See if there is an addendum published for the book.
The calculation is laid out pretty succinctly. Because the circuit has feedback, he has to break the loop and do some calcuation and then close the loop for the final gain. G1 is the through gain. G2 is the gain (loss) of the loading effect of the RF.
He first calculates the input impedance (open loop) for the follower and the CE amp. This is reflected emitter load of Q1 in parallel with Q2's load. He grinds this down to 180K (994K||220k). The .9879 is the fraction of the input that gets divided by the 2.2k and Rin. He calls this little alpha. This is what you'd expect from a follower. He doesn't use this further- just uses 1.
The G1 calc has the wrong value for RE1 but is the gain of the first stage. The second product term is the gain of G2 with collector load being RL2 in parallel with RF. G1 comes out to -105.7. Slightly wrong because of RE1 error- but very little.
G2 is the loading effect of RF on the 15K output Z- it is negligible. So the total gain G is the sum -105.6. H is the feedback factor, = Rb/(RF+rb), about 1%.
1+GH is denominator of the feedback circuit which is 2.0433. This is loop gain that the open loop gain gets reduced by- to give a gain of -51.
The last couple of steps recalculate rin and rout based on the actual loop gain at zero input.
I don't understand the H calc completely- he's referencing Blackman's definitions for a very old Bell Labs paper.
The final spice results might actually agree if the 5.57k and 7.5k were fixed?
Good luck on your quest- messy derivation. I think this designed as a learning lesson which is made harder by a typo.
Take Care
Hi there,
I am not sure how you concluded that he used 5.57k in place of 7.5k for RE1 in:
"Examples-
RE1 is 7.5K in the spice circuit and netlist but the author uses 5.57K in his hand analysis."
My analysis tells me he actually did use 7.5k as follows.
Following his first formula from the paper for ri (not mine BTW) I get:
ri=(B1+1)*(((B2+1)*RE1*(RE2+re2))/((B2+1)*(RE2+re2)+RE1)+re1)
and since he is using the same Beta for both transistors we can make B2=B1 which simplifies it a little bit:
ri=(B1+1)*(((B1+1)*RE1*(RE2+re2))/((B1+1)*(RE2+re2)+RE1)+re1)
Since B1=170 and re1=244 and re2=26.6 then:
ri=171*((171*RE1*(RE2+26.6))/(171*(RE2+26.6)+RE1)+244)
and this corresponds to the second line.
If we divide by 171 and then subtract 244 we get a resistance:
Rx=(171*RE1*(RE2+26.6))/(171*(RE2+26.6)+RE1)
Now with RE1=7500 and RE2=100 we end up with:
Rx=5570.233218748 Ohms.
This matches the paper which states "5.5700k" close enough.
Then we can match the paper again:
ri=(171)*(244+5570.233218748)=994233.880405908
which seems close enough to 994.2k.
I did not go over the whole thing like how he developed the forumlas in that paper, I just started with what was written first and took it from there.
Next I'll go over the whole formula from scratch.
