Author Topic: Stripping Magnet Wire  (Read 24051 times)
Offline CaptnYellowShirtTopic starter
  • Scooty Puff Jr.
« on: March 21, 2014, 05:00:03 am »
How do you strip magnet wire?
I've always resorted to 1000 grit sand paper, but its tedious work and leaves the end thinner (and more brittle) than it should be.
« Last Edit: March 21, 2014, 05:01:55 am by CaptnYellowShirt »
Offline Psi
Re: Stripping Magnet Wire
« Reply #1 on: March 21, 2014, 05:04:45 am »
I use a scaple blade and scrap the desired length.
It takes about 8 passes at 45deg around the circumference.
« Last Edit: March 21, 2014, 05:22:06 am by Psi »
Offline Po6ept
« Reply #2 on: March 21, 2014, 05:11:12 am »
A puddle of solder on your iron tip will often do the trick.  The enamel usually comes right off.  You can also try dipping the wire end into a small amount of lacquer thinner, but I usually just use a hobby knife as Psi suggested
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 21, 2014, 05:21:44 am »
Depends on type.  Old (actually enamel, usually brown) doesn't come off with heat and has to be scraped off.
Almost anything new is going to be a solderable polyester or polyurethane type, which burns off under the solder.  Apply plenty of solder, flux and use a relatively high temperature (400C or so) if your iron is adjustable.
Of course, the hottest magnet wire coatings are polyimide based and do not come off; they again must be scraped or whatever.  Or there might be some ridiculously nasty chemicals, but...
Seven Transistor Labs, LLC
Offline ivaylo
« Reply #4 on: March 21, 2014, 05:34:02 am »
Burn it with a match then clean with IPA or similar.
Online johansen
« Reply #5 on: March 21, 2014, 06:26:35 am »
boil it in battery acid.
other methods i've heard work involve a solder pot filled with sodium hydroxide and potassium nitrate.. and watch your eyeballs!
Offline rr100
« Reply #6 on: March 21, 2014, 06:35:28 am »
If soldering iron isn't hot enough then a match or lighter should do the trick. Wipe it with a tissue while it's hot and if it doesn't break it should be nice and clean. Or use fingers and nails >:D
I know people who have to mind which finger are using to probe if something (like a transistor radiator) is hot because some of the fingers are already pretty much "adapted" to hot terminals (while soldering), some occasional solder here and there, etc.
Offline FoXX
« Reply #7 on: March 21, 2014, 12:13:50 pm »
Simple question:
What is magnet wire?
/FoXX
Offline lapm
« Reply #8 on: March 21, 2014, 12:21:24 pm »
Simple question:
/FoXX
Coated solid core copper wire. If you have ever taken a part transformer, coil, etc... you have seen this stuff. Coating is usually very thin on these.
Electronics, Linux, Programming, Science... im interested all of it...
Offline N2IXK
« Reply #9 on: March 21, 2014, 04:45:29 pm »
Once upon a time, there was a commercial goop called "Strip-X" for doing this. Just dip the end of the wire in it, wait a few seconds, and wipe the softened enamel off. Worked great! I think GC electronics sold it, but haven't seen it in years, so it probably contained some really nasty substance that got banned at some point.
Some folks claim good results by placing the wire end on an aspirin (not acetaminophen or other) tablet, and heating with a soldering iron, melting the wire down into the tablet. This only seems to work on some insulation formulations, not all of them. And it stinks...
If you aren't dealing with heat strippable "thermaleze" insulation, then scraping with a razor blade/scalpel or sanding with fine grit emery paper is the way to go.
"My favorite programming language is...SOLDER!"--Robert A. Pease
« Reply #10 on: March 21, 2014, 05:06:25 pm »
Fine 800-1200 grit waterpaper pieces glued inside a wooden clothes peg, and wipe the wire through the jaws. You need the 2 part clothes pegs with a spring, not the US split type.
Offline Phaedrus
« Reply #11 on: March 21, 2014, 05:20:00 pm »
Lagunitas, or do you have to use Stone?
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline N2IXK
« Reply #12 on: March 21, 2014, 05:46:43 pm »
If you use Stone, it has to be the "Enjoy By", and within the allotted time.
I prefer Dogfish Head 120 Minute, myself. That stuff will clean anything... :-+
Offline JackOfVA
« Reply #13 on: March 22, 2014, 12:10:50 am »
Knipex model 15 11 120 coated wire stripper. http://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1363&groupID=1390
I bought one along with a complete set of jaws a couple years ago and use it nearly every day. Great tool.
I also use a solder pot for self-fluxing magnet wire, but not all magnet wire is this type. And if you strip most of the insulation away before using the solder pot, it does not develop the crud on top nearly as fast.
Also, the old GC "Strip-Ex" is no longer available, but there's a more or less equivalent product available at hardware stores. It's a paint stripper for "hard to remove" paint. Can't recall the name at the moment, but I bought some a few years ago - it has the same consistency -- halfway between a gel and a normal liquid -- and will remove standard magnet wire insulation. But I have not used it after acquiring the Knipex tool.
Offline Richard Head
« Reply #14 on: March 27, 2014, 08:55:30 am »
There are a few options:
1. A scalpel as mentioned.
2. A special stripper that looks like a pair of tweezers with blades that you pull over the wire. Quite easy to use.
3. A special handheld machine that has 3 round rotating blades that spin and strip the wire as you pull the wire through them. Not suitable for very thin wire.
4. Chemical stripper. Nasty stuff that fumes and eventually dries out and if it isn't neutralised it can corrode the wires afterwards.
If the wire is Polyurethane coated you can use a soldering iron or solder pot, no problem. Unfortunately PU wire cannot handle high temp operation so isn't suitable for high power density transfomers.
I have heard that if you heat the wire to red and dip it in methylated spirits (methyl alcohol) the insulation peels off. Sounds dubious and dangerous.
Dick
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #15 on: March 27, 2014, 04:30:55 pm »
Heat to red hot then dip to IPA or ethanol, works pretty well.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline IanB
« Reply #16 on: March 27, 2014, 05:08:25 pm »
I'm pretty sure that heating a wire to red hot and dipping it in ethanol (denatured alcohol, methylated spirits) runs the risk of the alcohol catching fire. Since alcohol burns with a nearly invisible flame, this is very dangerous. Many people have been admitted to hospital with severe burn injuries related to alcohol vapor explosions.
Don't mix naked flames, red hot wires and alcohol on the same bench!  :o
The following users thanked this post: Lomax
Offline DaveW
    • WattCircuit
« Reply #17 on: March 27, 2014, 05:21:59 pm »
In lieu of the chemical strippers, formic acid works extremely well and costs much less, I tend to use this when heat alone won't shift the insulation. Try not to smell the acid though... The knipex strippers also work very well
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #18 on: March 27, 2014, 05:29:54 pm »
These look like they work nicely but you need one for each wire size.
Offline casinada
« Reply #19 on: March 27, 2014, 08:35:14 pm »
Fire and IPA, can't get simpler than that. :)
Offline Smokey
  • Not An Expert
« Reply #20 on: March 27, 2014, 08:44:55 pm »
This is one of those "Right tool for the job" kind of things.  Sure you can MacGyver it, and it might look ok with your naked eyeball, but that doens't mean it's done right.
The magnet wire has to be be the kind which is intended to have the insulation come off with heat for that to work.  They all aren't like that like people have said.
Watch out with the xacto knife scrape method.  Take a look at the wire under a real microscope after you are done and you will see why.  The blade ends up nicking the wire all over the place.  Expect your equivalent wire gauge to be half what it used to be at least because of all the cuts and flat spots.  Plus it will break at the cuts when you try to wind it around something like a transformer pin.
It's kind of like using a pair of paper scissors for stripping insulated multistranded wire.  It might get the insulation off, but you'll be taking a bunch of strands with it.  If you will be doing it more than once, get the wire stripper.
  • Scooty Puff Jr.
« Reply #21 on: March 27, 2014, 10:59:45 pm »
That's why I always use my teeth.  ^-^
Offline Smokey
  • Not An Expert
« Reply #22 on: March 27, 2014, 11:34:05 pm »
You have to wonder where inspiration for some things might have come from....
Offline robrenz
« Reply #23 on: March 18, 2015, 12:40:39 pm »
Very compact DIY solution in this thread
Online TimFox
« Reply #24 on: March 18, 2015, 12:53:32 pm »
If you are using a blade or similar mechanical stripper, be careful to remove the enamel all (or mostly) the way around the wire.  Since some enamels are vaguely copper-colored, it can be easy to miss some resulting in a questionable final connection.
