Author Topic: Strange SOIC-8 package size?  (Read 6329 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: November 26, 2020, 03:16:56 am »
While placing components in KiCad am I stumbled upon a component that in the datasheet says it's a "SOIC-8(M)" package, it measures 5.99 mm while KiCad and the internet states it should be 4.9 mm, no matter type.
Here are the link to the datasheet: https://www.mouser.dk/datasheet/2/268/micrf002_022-1891338.pdf
Below are two images from page 18 on the datasheet and kiCad.
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline wraper
  • Country: lv
Re: Strange SOIC-8 package size?
« Reply #1 on: November 26, 2020, 03:28:57 am »
5.99mm or about is the standard dimension for SOIC. Dunno how you got that 4.9mm figure.
Offline MarginallyStable
« Reply #2 on: November 26, 2020, 03:29:57 am »
Would trust a component datasheet over what "KiCad and the internet says" There are so many variations of package types.
Offline wraper
  • Country: lv
« Reply #3 on: November 26, 2020, 03:35:17 am »
4.9mm is more like VSSOP/MSOP
Offline Nerull
« Reply #4 on: November 26, 2020, 04:08:25 am »
You're looking at the wrong dimension: width vs length. Both kicad and your datasheet agree that a SOIC-8 is 4.9mm long.
KiCAD uses E x F, your datasheet lists H and F
« Reply #5 on: November 26, 2020, 04:15:08 am »
I did get the measurement from both KiCad and several datasheets, but have now found this https://www.vishay.com/docs/83247/83247.pdf
LOL okay, have I measured the wrong dimension?? :-)
So the 3.9 mm is not the short dimension but the "innermost" size?
Offline exmadscientist
  • Technically A Professional
« Reply #6 on: November 26, 2020, 04:29:29 am »
Yes, 3.9mm is the body dimension rather than the leads dimension.
I've attached JEDEC MS-012 Issue F, which is about as close to "official" as it gets for a definition of SOIC (Narrow) parts. It is unpleasant to read, but it is authoritative.
Offline Nominal Animal
« Reply #7 on: November 26, 2020, 05:30:14 am »
You can also use EasyEda (online free EDA, with a simple browser-based user interface) to explore a lot of "official" part footprints (those sold by LCSC.com).
« Reply #8 on: November 26, 2020, 12:59:16 pm »
Thanks to you all am I a big step further:-)
By the way, I have no idea if this circuit will work, should I ask my questions here or start a new thread with the right tittle?
Offline jmelson
« Reply #9 on: November 26, 2020, 04:33:05 pm »
There is body dimension, edge of lead dimension, center of pads to center of pads dimension, and outer edge to outer edge measure.
All different, you have to be sure what the measurement refers to.
Jon
« Reply #10 on: November 27, 2020, 04:31:04 am »
Yes that's important to double and triple check! Thanks for your constructive comment! :-)
