I have a dark brown 2W(I think) carbon composite resistor that has
the color code Yellow Violet Gold Gold Blue
I have no idea how to read this resistor with gold being the third digit. It measures open circuit on the ohm meter so I can't find its value that way.
It is at the input of a SMPS on a refrigerator control board before the full wave bridge diode array.
I have seen pics where the resistor appears to be a different code than mine. The other code I have seen is Yellow Violet Gold Silver Blue.
The TNY267G before the transformer is shorted out and that seems to have killed the resistor.
It is R65 on the right hand side of this picture at the bottom above the blue MOV. This isn't my board but one of the many pictures I have seen of it online with the silver stripe instead of gold.
Any help would be greatly appreciated! I've got a new TNY267GN and some opto isolators that seemed to be burnt out along with new caps on the way from digikey. Hopefully can get this thing fixed.
