Author Topic: storing small dill bits <1mm  (Read 3901 times)
Offline ChopsticksTopic starter
« on: July 06, 2015, 05:31:03 am »
hi everyone,
i haven't posted much on here as I've been side tracked from my electronics hobby the last 12-18months but i'm wondering what the best way to store drill bits that are 1mm or smaller in size?
i have a whole container full of small drill bits that I've just sorted and stuck some labels on to tell me what sizes they are but its not a very practical way to leave them so im hoping somebody has some ideas on a more efficient way of storage
regards,
matt
Offline BennVenn
    • BennVenn's site
Re: storing small dill bits <1mm
« Reply #1 on: July 06, 2015, 05:49:41 am »
I've got a set of bits for drilling Jets in carbs, They came in a very nice linear storage box where you select the bit you want by sliding the top to align a small hole with the desired bit. That worked great for years until I dropped it and 30 tiny bits went flying across my garage floor... Now I have 25 tiny drill bits..
I've seen similar sets on eBay, you can't have too many drill bits!
Offline NoItAint
« Reply #2 on: July 06, 2015, 06:36:44 am »
Search for a "bur box"
Or a piece of paper with sizes on a stick of bees wax.  Stab the drill bits in.  Bees wax is good for drilling lube anyhow.
Maybe a worn out solderless breadboard  :)
« Reply #3 on: July 06, 2015, 07:25:59 am »
Plastic pill bottle for all sizes to 3 mm and the ever handy calipers at close reach.
Proper drill index for all the others to 13mm.
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« Reply #4 on: July 06, 2015, 07:58:57 am »
cigar tube, that's where I store mine. So long as you don't shake it like a rattle and put it somewhere dry.
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline rollatorwieltje
  • I brick your boards.
« Reply #5 on: July 06, 2015, 08:13:36 am »
My small drill bits came with this type of packaging:
http://www.rose-plastic.co.uk/2936.0.html
Not too bulky and you can write the size on the box.
Offline alsetalokin4017
« Reply #6 on: July 06, 2015, 09:53:16 am »
Remove sewing needles, install drill bits.
Offline george graves
« Reply #7 on: July 06, 2015, 10:17:29 am »
I order my bits from drill bit city (I think they have a yahoo store, an ebay store, and a normal web site)
Anyways, when I do, they come in a really awesome storage compartment - but it's for PCB drill bits with a 1/4 shank.
Something like this - but the ones I get usually SLIDE open(not clam shell), and protect the bits really well.
« Reply #8 on: July 06, 2015, 10:20:52 am »
Thanks everyone for all the helpful suggestions, I've go a few great ideas from you all so now I've just got to choose what one to use
Thanks again everyone for your help
« Reply #9 on: July 06, 2015, 06:41:15 pm »
High density polyurethane foam block, and poke them into it. Then put in a small box that will fit the foam.
Offline mazurov
« Reply #10 on: July 06, 2015, 06:55:36 pm »
Places that sell expensive bits send them in nice boxes, like the one on the picture. Such box tends to last much longer than the bits, I use it to store bits bought on eBay.
With sufficient thrust, pigs fly just fine - RFC1925
Offline edavid
« Reply #11 on: July 06, 2015, 07:37:03 pm »
A really cheap method is to use corrugated cardboard to make a sort of drill index.  The cardboard goes on edge, and you slip the bits into the corrugations.
Then you stick a piece of paper on the front to write the sizes.  Obviously the cardboard has to stay vertical, or all the bits fall out.
