Author Topic: storing data at 100Mhz  (Read 4810 times)
Offline abhimanyuTopic starter
« on: September 12, 2010, 09:58:22 am »
hi
i want to store 10byte parallel data being recieved at a speed of 100Mhz
precisely speaking the data is valid for 6ns and then for the next 4ns it settles to the next value
the total data will be about 200Kbytes
after 200KB is filled this data is to be send to the computer ( till the data is send to computer no new data comes in )
i have been looking for ram, counters, cpld, but could not figure put how to achieve this efficiently by spending  not more than 40$
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: storing data at 100Mhz
« Reply #1 on: September 12, 2010, 10:15:52 am »
Ok, so you need an data logger for less than 40$  , it will not happen in this life .. sorry .
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: September 12, 2010, 11:33:01 am »
A small FPGA or CPLD and some fast external SRAM would do this easily, and less than $40 in part, but not once you've put it on a PCB.
Do you mean 10 bytes or 10 bits? 10 bytes is doable but you'd have a very wide bus, and will be well out of your price target
Many FPGA devboards have SRAM, but you'll have to pay a little more. You will probably struggle to find a board with fast enough SRAM, but slower, wider RAM is another option.
Probably the cheapest would be to use a reasonably wide SDRAM  with a FIFO in the FPGA to cover the setup periods.
For PC download something with onboard USB, would be useful to make a single-board ready made solution - I'm sure there is something out there, but not for $40.
This product might be an option. There are plenty more out there.
« Last Edit: September 12, 2010, 11:39:05 am by mikeselectricstuff »
Day Job: Mostly LEDs
Online NiHaoMike
    • Facebook Page
« Reply #3 on: September 12, 2010, 01:07:42 pm »
Some common (and very cheap if you know where to get it) PC133 will do that nicely.
alm
  • Guest
« Reply #4 on: September 12, 2010, 01:21:49 pm »
Getting the data in there will probably be not so cheap.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: September 12, 2010, 07:50:39 pm »
10 bytes x 100MHz = 1GB/s? to computer? jeez! i have Arduino data logger for around $40 allright! but not at this 1GB/s!
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #6 on: September 13, 2010, 06:57:06 am »
No I think he wants to acquire at 100MHz and then send a block of 200KB to a computer, basically he wants a buffer to take a shot of 200KB at 100MHz and then send it on in it's own time before acquiring more
  • Country: my
« Reply #7 on: September 13, 2010, 11:36:22 am »
oo ok. but still 1GB/s to RAM during less than 200KB is achieved. still quite almighty. maybe parallel RAM will do the trick. never look into the detail of RAMing though.
alm
  • Guest
« Reply #8 on: September 13, 2010, 11:50:26 am »
He basically needs a fast FIFO, but I think 80 * 2500 at 100MHz is pretty expensive (IDT72V3660L6PFG, 4Kx36 166MHz FIFO is about $50 each, and you'd need three for 80 bits wide). But you'd need an FPGA for external SDRAM, which is expensive, too.
My guess is that you won't get a solution for under $40 unless you either change the specs or the budget, unless you can reuse some existing equipment that you can get cheaply.
« Reply #9 on: September 13, 2010, 04:12:35 pm »
okk
so let me think on my design and budget once again
i will be back once i am done with the changes in the design to reduce data rate or to increase my budget
thanks you everyone for your inputs
