Author Topic: SSR question  (Read 1908 times)
Offline Lucky-LukaTopic starter
SSR question
« on: May 04, 2022, 07:46:22 am »
Hi all
Can anyone tell me how can this relay be ok with such a broad input voltage?
I haven't found a schematic for this kind of relay module.
Thanks
https://www.ebay.it/itm/322209858572
Memento audere semper.
Online wraper
  • Country: lv
Re: SSR question
« Reply #1 on: May 04, 2022, 08:02:35 am »
It's not a mechanical relay but SSR (solid state relay). It has a circuit that limits the current flowing through LED emitter of optocoupler. 3-32V input voltage range is the most common for SSR. Older types often had around 5V minimum voltage.
« Last Edit: May 04, 2022, 08:04:26 am by wraper »
Re: SSR question
« Reply #2 on: May 04, 2022, 11:45:32 am »
GTD-W-5A
I haven't found a datasheet to understand the current needed for the control input
Online wraper
  • Country: lv
Re: SSR question
« Reply #3 on: May 04, 2022, 11:55:30 am »
It self limits the current. If source is capable to supply at least 20-30mA, generally you should be fine.
Re: SSR question
« Reply #4 on: May 04, 2022, 12:59:50 pm »
So I cannot drive it using a GPIO pin of an Arduino...
I need a bjt or a mos with that relay, right?
Offline Terry Bites
Re: SSR question
« Reply #5 on: May 04, 2022, 01:06:34 pm »
The description says the relay will be on when the control input excedes 3V and off when the control volage is less than 0.5V.
It also says that the relay state for control voltages between 0.5-2.5 is not defined, it might be on or off or random.
The maximum control voltage is 32V.
They say it can be driven from an Arduino. This is cause for concern, the worst case output voltages may be out of specification for this relay. 1478002-0
You do need to add a a driver to the GPIO. eg1478008-1
The following users thanked this post: Lucky-Luka
Re: SSR question
« Reply #6 on: May 04, 2022, 02:01:27 pm »
then couldn't I just use a power mosfet instead of a relay and that bjt?
Offline CaptDon
  • Country: is
Re: SSR question
« Reply #7 on: May 04, 2022, 02:09:17 pm »
That depends somewhat on what load you intend to drive and if that load is inductive and may sens inductive kick-back spikes into your digital world. The SSR gives you the benefit of superb isolation between the driving signal and the load. It also allows for loads connected to other voltage sources, in some cases (the usual use) even the A.C. mains.
Re: SSR question
« Reply #8 on: May 04, 2022, 02:52:12 pm »
Why?
Online wraper
  • Country: lv
Re: SSR question
« Reply #9 on: May 04, 2022, 04:00:11 pm »
Why? Atmega328 is allowed to supply 40mA per pin (with limitation on overall current thru multiple pins).
Re: SSR question
« Reply #10 on: May 04, 2022, 04:13:04 pm »
Post #5
Online Zero999
  • 0999
Re: SSR question
« Reply #11 on: May 04, 2022, 04:40:53 pm »
What's the supply voltage? If it's 3V, the output voltage will be too low.
Online wraper
  • Country: lv
Re: SSR question
« Reply #12 on: May 04, 2022, 04:42:28 pm »
Arduino uses 5V.
Online Zero999
  • 0999
Re: SSR question
« Reply #13 on: May 04, 2022, 04:44:25 pm »
Arduino uses 5V.
It should be fine, if it doesn't push the total current draw above 200mA.
Offline james_s
Re: SSR question
« Reply #14 on: May 04, 2022, 05:24:13 pm »
I have driven SSRs directly from Arduinos (and other AVRs) without any issues, it will be fine.
Offline BeBuLamar
Re: SSR question
« Reply #15 on: May 04, 2022, 08:14:57 pm »
GTD-W-5A
Most SSR only needs about 10mA.
Re: SSR question
« Reply #16 on: May 07, 2022, 08:54:13 am »
Arduino uses 5V.
I am using an Arduino that runs at 3.3V
Re: SSR question
« Reply #17 on: May 07, 2022, 08:54:48 am »
Arduino uses 5V.
I use a 3.3V Arduino
Online Zero999
  • 0999
Re: SSR question
« Reply #18 on: May 07, 2022, 12:22:29 pm »
Arduino uses 5V.
Then use the circuit posted by Terry Bytes.
https://www.eevblog.com/forum/beginners/ssr-question/msg4154950/#msg4154950
Re: SSR question
« Reply #19 on: May 07, 2022, 03:41:21 pm »
That works if I don't have an octocoupler on the module
