Author Topic: wire strippers.  (Read 2297 times)
Offline ShadyKTopic starter
wire strippers.
« on: April 05, 2014, 11:37:05 am »
http://m.screwfix.com/p/forge-steel-160mm-wire-strippers/54067?filtered=true will these be ok to use to strip coax cable ?? Or are they no good?
Tac Eht Xilef
  • Guest
Re: wire strippers.
« Reply #1 on: April 05, 2014, 12:07:11 pm »
No good for coax; they're meant for standard insulated wire only.
The same site has a couple of coax strippers - the rotary one is OK if you're doing the same type/size cable all the time, the other type is more useful for occasional use stripping different diameter cables.
Offline scott216
Re: wire strippers.
« Reply #2 on: April 08, 2014, 02:49:53 am »
I use something like these: http://amzn.to/1ennPqq
You spin it around the wire.
