also IMO k-weld is not over priced. I think its well made and works well.
Cheaping out on welding equipment is never a great idea.
If you save scrap metal (thin brackets, sheet, etc) you can build impressive prototypes for various things using it to quickly make its moneys worth. And it can do some impressive things like weld stainless steel screens to things, for vent screens, etc.
Its literally how you can use literal scraps to make something like in a RPG video game (alien isolation, etc)
Like once you realize you can build something from old steel computer bay rails using nothing but tin snips and a file, its impressive. Basically any thin steel bracket can be repurposed to mount basically anything using a spot welder and a dremel. That weird half arch thing from a dell computer... can now be used for something.
And its strong as hell and has actual electrical properties (unlike 3d printers).
I will literarly go out of my way to harvest esoteric sheet metal parts from whatever now so long they are reasonable because it can be used in conjunction with the spot welder to mount basically anything in a sturdy way. and also there is no CAD involved. Caliper scrapes are enough to mark out anything. Transfer screws are useful too.
There is so much structural bullshit you can take out of equipment that can be reused for high quality prototypes using a spot welder to join it with minimum work. It actually feels like tinkering, not machine shop, not cad-jockey, not automation machinery technician. literal tinkering.
You might think what makes it any better then solder? The answer is speed, ease and greater parts utility. You could solder alot of steel stuff together but the fact is, you have annoying prep to do. Alot of it. And you need to fixture to solder properly, plus there is often thermal problems. With the spot welder so long you have flats you use the electrodes to fixture and its like playing GMOD irl. How about small bolts? well you have tons of crap to do, that is locate, drill, deburr, tighten. With spot welding its way less work. That means easy to make complex structures without sitting around all day figuring about how to drill things. And, if you have a esoteric joint that needs solder or braze, the welds you made for the majority of the structure can hold easily.
